For some reason, when I try to raise my volume, the volume levels auto-adjust down to its lowest setting.
What is this? Please help!
Check all sound and volume settings to make sure you don't have any auto settings on.For some reason, when I try to raise my volume, the volume levels auto-adjust down to its lowest setting.
Where would I see these auto settings?Check all sound and volume settings to make sure you don't have any auto settings on.
Go into Settings, Sound, Volume and there's a three dot area on right side you go into for that screen shot I displayedWhere would I see these auto settings?
Do you May be have DoNotDisturb onCheck these out. It won't even let me change from "Vibrate" to "Sound."
View attachment 279023View attachment 279024
Just all the screen options where volume can be controlledThanks. (What are you showing me?)
Yeah, when I do that, it switches back automatically.Press on Sound Mode where it says Vibrate. Should allow option to change to Sound.
What launcher are you onYeah, when I do that, it switches back automatically.
Me too. Maybe there is a permissions setting within Nova. ILL check and seeNova Launcher Prime.
Don't think there's a nova setting for sound control.Me too. Maybe there is a permissions setting within Nova. ILL check and see
