02-15-2018 03:05 AM
46 12
tools
  1. Dankees's Avatar
    For some reason, when I try to raise my volume, the volume levels auto-adjust down to its lowest setting.
    What is this? Please help!
    02-11-2018 04:14 PM
  2. amyf27's Avatar
    Check all sound and volume settings to make sure you don't have any auto settings on.
    02-11-2018 04:40 PM
  3. Dankees's Avatar
    Where would I see these auto settings?
    02-11-2018 04:41 PM
  4. amyf27's Avatar
    Aside from vume settings try to check this area
    02-11-2018 04:41 PM
  5. amyf27's Avatar
    Go into Settings, Sound, Volume and there's a three dot area on right side you go into for that screen shot I displayed
    02-11-2018 04:42 PM
  6. Dankees's Avatar
    Check these out. It won't even let me change from "Vibrate" to "Sound."
    Volume Auto-Adjusting Down-screenshot_20180211-174445.jpgVolume Auto-Adjusting Down-screenshot_20180211-174508.jpg
    02-11-2018 04:46 PM
  7. amyf27's Avatar
ID:	279023Click image for larger version.
    Do you May be have DoNotDisturb on
    02-11-2018 04:47 PM
  8. amyf27's Avatar
    02-11-2018 04:47 PM
  9. Dankees's Avatar
    Nope, look at the long screen shot.
    02-11-2018 04:48 PM
  10. amyf27's Avatar
    02-11-2018 04:48 PM
  11. amyf27's Avatar
    Press up on the volume button jist two times on the phone. It shows you have sound off and on vibrate. Odd.
    02-11-2018 04:50 PM
  12. Dankees's Avatar
    02-11-2018 04:51 PM
  13. amyf27's Avatar
    Press on Sound Mode where it says Vibrate. Should allow option to change to Sound.
    02-11-2018 04:51 PM
  14. amyf27's Avatar
    Thanks. (What are you showing me?)
    Just all the screen options where volume can be controlled
    02-11-2018 04:52 PM
  15. amyf27's Avatar
    I have mine set to Sound, no Vibrations.
    02-11-2018 04:52 PM
  16. Dankees's Avatar
    Yeah, when I do that, it switches back automatically.
    02-11-2018 04:53 PM
  17. amyf27's Avatar
    What launcher are you on
    02-11-2018 04:53 PM
  18. Dankees's Avatar
    Nova Launcher Prime.
    amyf27 likes this.
    02-11-2018 04:54 PM
  19. amyf27's Avatar
    Me too. Maybe there is a permissions setting within Nova. ILL check and see
    02-11-2018 05:07 PM
  20. amyf27's Avatar
    Don't think there's a nova setting for sound control.
    Check your pull down menu
    02-11-2018 05:14 PM
  21. Dankees's Avatar
    Check your pull down menuhttps://uploads.tapatalk-cdn.com/201...7773ad6d9b.jpg
    What should I look for in there?
    02-11-2018 05:23 PM
  22. amyf27's Avatar
    Make sure do not disturb is not selected
    02-11-2018 05:25 PM
  23. amyf27's Avatar
    On my drop down I just have sound location and auto sync selected
    02-11-2018 05:26 PM
  24. Dankees's Avatar
    It's not.
    02-11-2018 05:31 PM
  25. amyf27's Avatar
    It's not.
    Not sure - maybe someone else can offer some tips. Make sure you go through all the sound settings, sounds like you checked the drop down menu too. Notice any changes after a recent update maybr?
    02-11-2018 05:33 PM
46 12
  1. do i always have to plug in my phone in my car in order to use android auto?
    Last Post: 02-18-2018, 04:13 PM
  2. Volume button defaults to media control
    By Android Central Question in forum Nexus 6P
    Last Post: 02-15-2018, 05:51 PM
  3. Volume button defaults to media control
    Last Post: 02-08-2018, 05:03 PM
  4. How can I turn down/adjust the volume of Google Assistant?
    By DesertTwang in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 02-08-2018, 04:55 PM
  5. My notification bar won't go down
    Last Post: 02-08-2018, 01:03 PM
