12-02-2019 04:35 PM
30 12
tools
  1. diagoro's Avatar
    Wifi settings, advanced - Turn off wifi pop-ups and wifi notifications if you don't want to see it.
    Just checked, all notification settings are set to off......yet I still get them.
    03-06-2018 12:59 PM
  2. Shawky Shamy's Avatar
    i have the same issue
    but not always
    sometimes my note 8 is normal on wifi and sometimes the speed is painfully sickfully slow
    i just cant browse anything
    while any of my devices are home are great with wifi
    i noticed that if i go out for couple of hours and come back , the wifi speed somes back to normal !
    any idea ?
    04-21-2018 03:16 AM
  3. Scooter278's Avatar
    On your phone wifi connections check if actually connected fully on both AC 5GHZ and 2.4GHZ. As possibly dropping one, finding other, but not actually signed in. I have not signed in to 2.4GHZ slow WiFi (forget network) as find stability and improved speed from only being connected to one WiFi network.
    04-21-2018 07:13 AM
  4. reom3's Avatar
    I was having a similar problem. I was only getting 6-9mbps on WiFi downloads while other devices were connecting at much higher speeds (60 to +100 Mbps). Did all the recommended "cleaning", cleared the cache, etc. The final step was to determine which app was causing the issue.
    Turns out it was Bixby. Noticed there was a lot of usage even though I never open it or set it up. You can acces Bixby's settings right in the app, not in the settings menu. After disabling all Bixby functions, my download speed jumped to 99.4 Mbps. Hope this helps others.
    06-20-2018 12:25 PM
  5. Madhven's Avatar
    The issue is with the wifi band. You should either disable the 5Ghz band or at least have two separate bands 2.4ghz and 5Ghz ones. When you connect note 8 to 2.4ghz band the speed will be much higher. On 5Ghz you need line of sight to have good speed. Many routers propogate both 2.4ghz and 5ghz on same ap name. If not clear ping me..will help out
    12-02-2019 04:35 PM
30 12
  1. The Verge Website slow
    By mesocyclone30 in forum General Help and How To
    Last Post: 03-05-2018, 02:37 AM
  2. I have LYF Wind 6 mobile phone facing storage problem.
    Last Post: 02-27-2018, 10:54 AM
  3. Why is my music stopping, when watching social media (snapchat,Instagram)
    Last Post: 02-27-2018, 10:33 AM
  4. Oukitel K6 - VoLTE function not appearing
    By excellfriend in forum Ask a Question
    Last Post: 02-27-2018, 07:10 AM
  5. other language fonts not showing in my andorid
    By jsadjsandj in forum Android 7.0 Nougat
    Last Post: 02-27-2018, 06:02 AM
