1. rajesh_note8's Avatar
    When I connected my Note 8 to my home wifi, I got the Security and Privacy popup to inform that I connected to Wifi Network "Prescott" with the following 3 options.
    Checkbox: Remember My Choice
    Button: Yes, disconnect
    Button: No, remain connected
    I checked the checkbox and by mistake I pressed Yes button instead of No button.
    When I tried to connect to my home wifi again, it is connecting first and immediately getting disconnected because of the choice I chose earlier. I couldn't clear this. Any advice?
    Thanks in advance.
    Note: When I connected my wife's cell phone to home wifi, I didn't make the same mistake, so her phone always connects. I have Verizon FIOS.
    boudicca00 likes this.
    03-16-2018 07:06 PM
  2. macallik's Avatar
    I think the easiest option is to go-to wifi networks, long press on your home WiFi network name, then click forgot network. Then reconnect and enter your password.
    03-17-2018 10:28 AM
  3. sydneycooper1979's Avatar
    I had the same problem with my Note 8. It was only my home WiFi. I did alllll the things and could never get it to stay connected. Best of luck!
    03-17-2018 11:44 AM
  4. rajesh_note8's Avatar
    Hi macallik, Thanks for the reply. I did what you told many times, didn't help. In fact, I changed my wifi name too, not resolved. I can connect to my neighbor's wifi (of course with his permission), the connection stays. Once I switched to my home wifi, it connects first and disconnects the next second.
    May be factory reset helps? But I don't want to do that since I have already configured my office emails, etc.
    03-19-2018 02:26 PM
  5. Trees's Avatar
    Has the Note 8 ever worked properly with the home WiFi?
    03-20-2018 07:21 AM
  6. rajesh_note8's Avatar
    I found the fix myself. In Security & Policy, Goto WiFi Networks, then Blocked Networks, Saw my Home Wifi is listed there. I selected it and removed it. My Note 8 is connected with my home Wifi and stay connected.
    Thanks.
    Jason Case1 likes this.
    03-20-2018 09:02 PM
  1. Replies: 2
    Last Post: 03-21-2018, 04:11 PM
  2. Why won't my Samsung keyboard ever come up?
    Last Post: 03-21-2018, 03:59 PM
  3. Smart Lock + 60 coordinates = my home address
    Last Post: 03-17-2018, 12:42 PM
  4. Can't convert .Avi to play on Moto e4
    By esjayy in forum Moto E4 & E4 Plus
    Last Post: 03-16-2018, 05:07 PM
  5. Unicorn adblocker for Samsung internet
    By 30k in forum Ask a Question
    Last Post: 03-15-2018, 05:56 PM
