1. monkeycsk's Avatar
    i find the volume for the stocked wired headset for the note8 is rather low even when i set the volume to max.
    however, when i use the apple airpod bluetooth headset, the volume is considerably louder which i find very interesting because i always thought wired headset is louder than any bluetooth headset.
    anyone has the same experience?
    04-08-2018 08:01 PM
  2. chanchan05's Avatar
    Being wired or not has nothing to do with volume. It's the drivers on the headset itself. Also, the ones bundled in the Note are in ear types, which means they expect you to get a decent seal to get proper volume.
    04-08-2018 08:04 PM
  3. monkeycsk's Avatar
    ok, so do you agree the volume for the note8's drivers is low?
    04-08-2018 09:32 PM
  4. chanchan05's Avatar
    No. It's similar to any in ear type of earphone. The issue is you need to get a good seal with the plugs.
    04-08-2018 11:36 PM
  5. j_hansen's Avatar
    I find the AKG ones fairly loud but my Spigen Bluetooth one are definetely louder, however, like previous poster said it is all about a good seal and the Spigen ones just seem to be a perfect fit for me.
    04-09-2018 03:45 AM
  6. amyf27's Avatar
    I use Beats by Dre bluetooth over ear headphones and have fantastic volume
    04-09-2018 09:46 AM
  7. chanchan05's Avatar
    Anyway, I actually find the included plugs small. So you might need to get third party plugs to make them work better, like Comply foam plugs.
    04-09-2018 09:58 AM
  8. monkeycsk's Avatar
    i agreed with you totally. my friend and i both find our stock wired headset has very low volume. i really don't think it has anything to do with seal.
    06-29-2018 01:11 PM
  1. bluetooth speakers
    By neuronetv in forum Samsung Galaxy S8 & S8+
    Last Post: 04-16-2018, 11:51 AM
  2. Vs note 8
    By donebrasko in forum Samsung Galaxy S9 & S9+
    Last Post: 04-08-2018, 06:00 PM
  3. I have volume turned all the way up
    Last Post: 04-08-2018, 01:44 PM
  4. lifeproof case volume buttons not working
    By Borarjti in forum Samsung Galaxy S8 & S8+
    Last Post: 04-08-2018, 06:20 AM
  5. Contacts not showing up in car Bluetooth paring
    By robotomo in forum General Help and How To
    Last Post: 04-07-2018, 08:25 PM
