I noticed that android system is burning through battery. I have set it to off for background running again.
That's the problem. It was turned off and battery was great. Then today it was running in background again causing major battery drain. Guess I'm gonna have to FDR this bad boy. Unless 71% left after being off charger for 5.5hrs seems good.Let us know how that works for ya.
That looks like normal battery usage to me.That's the problem. It was turned off and battery was great. Then today it was running in background again causing major battery drain. Guess I'm gonna have to FDR this bad boy. Unless 71% left after being off charger for 5.5hrs seems good.
Can you post a screenshot of your "Battery Usage" page from "Settings" after say 5.5 hours so we can see the "Recent Battery Usage" stats for comparison to our phones. Something doesn't sound right - mine doesn't run down that badly... I'm not a real heavy user, but still! What's it look like overnight after a full charge? I take mine off the charger at midnight (100%) and when I get up at 8:00AM it's at between 94-95% from standby. That dropped immediately after Oreo to 91-92% but it's back up again to where it was with Nougat without me doing anything (learning)?That's the problem. It was turned off and battery was great. Then today it was running in background again causing major battery drain. Guess I'm gonna have to FDR this bad boy. Unless 71% left after being off charger for 5.5hrs seems good.
Screen 3%. Android system 3%. And one other I forgot what it was but it was part of the system at 3%. I am a heavy user on most days so I do notice it. Seems like as soon as I either restart or shut of android system in the background it's fine. Guess I'm going to backup and FDR tonight and see if the bug remains. I had to charge it cause I'm at work and it was already at 61% by 12:30. Only 6.5hrs, but that may be normal.Can you post a screenshot of your "Battery Usage" page from "Settings" after say 5.5 hours so we can see the "Recent Battery Usage" stats for comparison to our phones. Something doesn't sound right - mine doesn't run down that badly... I'm not a real heavy user, but still! What's it look like overnight after a full charge? I take mine off the charger at midnight (100%) and when I get up at 8:00AM it's at between 94-95% from standby. That dropped immediately after Oreo to 91-92% but it's back up again to where it was with Nougat without me doing anything (learning)?
Yes and can't do. Needed for the wife. That was never an issue and doesn't seem to be the culprit.Do you, by chance, have location services set to High Accuracy? If so, try switching it to Battery Saving except for when you're actively using mapping.
FDR sux but hopefully it will clear up whatever is dragging the battery down - I really don't want to believe that is normal. I've had mine since they came out and never had that kind of battery life... Nougat or Oreo. Good Luck... let us know please!Screen 3%. Android system 3%. And one other I forgot what it was but it was part of the system at 3%. I am a heavy user on most days so I do notice it. Seems like as soon as I either restart or shut of android system in the background it's fine. Guess I'm going to backup and FDR tonight and see if the bug remains. I had to charge it cause I'm at work and it was already at 61% by 12:30. Only 6.5hrs, but that may be normal.
+1I've always found location service /gps to be quite battery draining, only turn it on if I actually need it, Bluetooth doesn't seem bad at all on the Note 8 though
