1. pdconner's Avatar
    They unlocked my phone so now it can be used on any carrier.. but I have a question.. does this mean i might get the update faster to Oreo or what does it mean to have it unlocked - is there any benefits other then just being able to put a sim in it for Verizon if i want to..
    05-11-2018 08:46 AM
  2. djrakowski's Avatar
    No, it doesn't mean that you'll get updates any differently than you did before. AT&T (rather than Samsung) will still push updates to your phone as they become available.
    pdconner likes this.
    05-11-2018 08:53 AM
  3. kitmo's Avatar
    Isn't it dependent on your carrier when updates are sent? I am unlocked on Virgin Mobile Canada and my updates are generally received by me in a timely fashion.
    05-11-2018 09:50 AM
  4. terobaje's Avatar
    Unlocked just means that it has no SIM restriction and you can use it with any carrier. The phone is still an AT&T phone so the updates will come from AT&T.
    05-11-2018 01:12 PM
  5. pdconner's Avatar
    Thanks Everyone......
    05-11-2018 01:30 PM
  1. Samsung s8+ stuck on Android 7.0
    Last Post: 05-11-2018, 08:39 AM
  2. WTS: Various Note 8 cases
    By amyf27 in forum The Marketplace - Buy, Sell & Trade
    Last Post: 05-11-2018, 04:23 AM
  3. Asking about my guest mode
    By Android Central Question in forum Android 6.0 Marshmallow
    Last Post: 05-11-2018, 02:15 AM
