1. droidntn's Avatar
    I bought this smart plug and my Note 8 won't connect. My son's S6 connects and works fine on the same home network.
    Anyone else have this plug or similar and use on your N8?
    Or any thoughts on why this is happening?
    Everything else connects and works fine on my phone.
    Thanks.
    06-07-2018 05:54 AM
  2. svtcobra's Avatar
    I had that problem at 1st. TP Link only works on the 2.4 ghz band. NOT 5 ghz. Make sure you are on the same band. Not only just the same network. Also, if you are using a VPN, it will Not connect. (sucks)
    06-07-2018 07:59 PM
  3. droidntn's Avatar
    RESOLVED: I finally fixed it. Not sure what exactly was the problem, but it must have been something to do with my setup. I added a new account, did the inital setup again and it works fine now.
    06-09-2018 07:31 AM
  1. Why you people not give answer in simple way
    By Arjun Lal Tamta in forum Android Games
    Last Post: 06-14-2018, 05:06 PM
  2. Mobile data connects to H+ instead of 4G.
    By venom0706 in forum LG G7 ThinQ
    Last Post: 06-12-2018, 07:04 AM
  3. Chrome not opening relevant app from link
    Last Post: 06-07-2018, 12:53 PM
  4. why my phone icon are not visible after using ultra power saving mood
    Last Post: 06-07-2018, 10:54 AM
  5. Why sumsung internet browser did not ask for download option ?
    By AsfaQfadiya in forum Samsung Galaxy A5
    Last Post: 06-07-2018, 10:24 AM
