    When I've received calls (not made outgoing falls) the phone drops the call after some minutes - maybe 3 to 5 mins - I look at the screen when I realize I'm talking to dead air and it tells me my phone has restarted and presents the keypad so i can log in. The call doesn't show on my log of recent calls so i have to wait for the caller to call me back (unless i know the #).
    This is frustrating as it is mostly professional not personal calls.
    Is this common? is there an easy fix? Thanks
    06-07-2018 02:39 PM
  2. Rukbat's Avatar
    I haven't seen it reported before, but since the phone is under warranty, I'd contact the seller for a replacement. (Make sure you back up anything important, then remove your Google account and do a factory reset before sending it back.)
    Is there an easy fix? Maybe, but it would probably void the warranty if they figured out that you did it.
    06-07-2018 04:40 PM
  3. jhimmel's Avatar
    That is not a common problem. Mine started dropping calls a few days ago, but this was not an issue I was having all along - just the last 4 days. So I went to Verizon for them to check it out. They replaced the SIM, and it has not happened again in the last 2 days, so hopefully that's it.
    06-07-2018 08:35 PM
  1. Replies: 1
    Last Post: 09-19-2018, 08:41 AM
  2. Replies: 2
    Last Post: 09-14-2018, 04:41 AM
  3. Why cant i hear when im on facebook asong or a speach
    By Android Central Question in forum Android Apps
    Last Post: 06-08-2018, 12:42 AM
  4. Replies: 1
    Last Post: 06-08-2018, 12:31 AM
  5. When I try to open my banking app, it is a blank screen.
    Last Post: 06-07-2018, 04:42 PM
