1. Nazdogg's Avatar
    Hi. I just noticed a small whote box at the edge of the screen. Narrow vertical at the edge of the screen, about 2 boxes high. It can be moved along the side but cant seem to get rid of it. Someone help me please!
    Thanks in advance
    07-27-2018 04:27 PM
  2. SpookDroid's Avatar
    That's the Edge Screen. If you hold and slide inwards, you should see your Edge Panels. You can, of course, disable this (or add more panels and customize size and position) from your phone's Settings (Settings/Display/Edge Screen)
    Laura Knotek likes this.
    07-27-2018 04:58 PM
  3. j_hansen's Avatar
    You can set the transparency to 100% so it will still work as intended but you can't see it but obviously need to remember where it is, I have done this and have it located just above the power button
    07-28-2018 02:09 AM
  4. donm527's Avatar
    Or you can go to the edge panels settings and just turn it off. If you weren’t using it until now and don’t care about it, you won’t miss it turned off. I rarely use mine.
    07-28-2018 09:22 AM
  5. Nazdogg's Avatar
    Ah ha. Thanks. Cos it suddenly appeared out of nowhere and i wasnt sure what it was. Cheers guys
    07-30-2018 01:28 AM
  1. Galaxy S9 and S9+ owners, were there any other phones you were considering?
    By TextMeMaybe in forum Samsung Galaxy S9 & S9+
    Last Post: 08-04-2018, 11:49 AM
  2. How do I change my name on cell phone that callers see displayed
    Last Post: 07-27-2018, 04:03 PM
  3. How to add attachment to a Textra Text on Android phone?
    Last Post: 07-27-2018, 03:45 PM
  4. How do I move the Google search bar to the desktop on my Android phone
    Last Post: 07-27-2018, 03:43 PM
  5. Replies: 0
    Last Post: 07-27-2018, 01:46 PM
