1. Sak2008's Avatar
    Battery charges to 100% but only getting about 17 hours of stand by time. Use to get 20 and the phone is only a month old. And stand by time drains faster then the %
    08-23-2018 02:05 PM
  2. Rukbat's Avatar
    17 hours to what percent? If you're using the battery until it gets close to 0, that's about to be expected. Lithium batteries are not deep-discharge batteries.
    If you're charging at about 40% (which is where you should). restart in Safe Mode and see how long a fresh charge lasts to 40%. (If it lasts longer that way, there's a "runaway app". Find out which one it is, and stop it. (Uninstall it unless you absolutely need it, then force stop it every time you're finished using it).
    08-23-2018 02:40 PM
  3. Sak2008's Avatar
    It only start a few days ago. I did how ever download a new update don't know if that has anything to do with it or not. thanks for the responses and help
    08-23-2018 07:39 PM
  4. donm527's Avatar
    The AT&T update a few days ago? One posted they were getting better life After the update. Mines been solid before and after the update.
    https://www.reddit.com/r/GalaxyNote8...MW&sh=adb646b3
    08-24-2018 11:40 PM
  1. Whitestone Dome on Note 9
    By jeffg9 in forum Samsung Galaxy Note 9
    Last Post: 11-21-2018, 11:25 AM
  2. How to get the most out of your battery
    By smooth4lyfe in forum Samsung Galaxy Note 9
    Last Post: 08-25-2018, 09:43 AM
  3. Problem with camera
    By Gillpet9 in forum Samsung Galaxy Note 4
    Last Post: 08-25-2018, 01:17 AM
  4. Why my battery have no icon when charging
    Last Post: 08-23-2018, 02:20 PM
  5. Why my battery have no icon when charging
    Last Post: 08-23-2018, 11:50 AM
