1. Ramy Adly's Avatar
    Dear all,
    I have an issue in note 8, now when the battery reaching 25% or 22% the charging is going down very fast, like 3 or 4 minutes to go from 22% into 8% and then the mobile powerd off automaticaly with 0%.
    I need your urgent feedback.
    09-15-2018 06:59 AM
  2. Preach2k's Avatar
    It is rare, but sometimes a single app can drain a significant amount of battery.
    If you have a badly made app installed it can still drain your battery faster than you'd like. Unfortunately that means you still need to be diligent about checking battery usage — particularly if you're tipped off by a battery that isn't lasting as long as it should.
    To check on apps that are using a large chunk of your battery, head into the phone's Settings, Device maintenance and then Battery to see a readout of which apps are using significant power. It isn't uncommon to see apps using 1-3% battery over the course of a day, but if you see one in the 5-10% range you should consider uninstalling it, or at least clearing its data and starting fresh with it in case something had gone wrong with its configuration.
    09-15-2018 07:16 AM
  3. Ramy Adly's Avatar
    Please be noted with the following and appreciate your advice.
    Screen 13%
    Device idle 5%
    Call standby 3%
    Wi-Fi 1%
    That's all what i have when I go to device maintenance and then battery, Appreciate your support please.
    09-15-2018 03:17 PM
  4. Ramy Adly's Avatar
    Screen 13%
    Device idle 5%
    Call standby 3%
    Wi-Fi 1%
    09-15-2018 03:17 PM
  5. gernerttl's Avatar
    Check to see if you have any un-monitored apps using battery. I check that periodically and remove any from the un-monitored apps.
    09-16-2018 12:55 PM
  6. blucasmobile's Avatar
    Reboot to factory and delete all third party apps. Add only the essential ones, one at a time. See which ones are battery hogs.
    Social media is the worst, weather apps, Internet security apps.
    09-26-2018 07:46 PM
  7. mike104393's Avatar
    I would suggest doing what others have suggested. Do a factory reset on the device and see how it goes. My note 8 was feeling sluggish and battery was draining very fast. Decide to replace it through Samsung premium. So glad I did, as if resolved the problem.
    09-26-2018 08:36 PM
  8. Elenayap's Avatar
    like happened to me , the problem is app that running at background drain battery , check your apps one by one , find that use data at background
    09-30-2018 10:00 AM
  9. littlemissImperfect's Avatar
    just got mine 2 days ago,arranged all my settings, seemed fine until today. In 20 minutes i went from 70% to 61% , 1% just disappearing after a restart. I'm going to try the factory reset when i get back home since i was in a hurry and just transferred everything from my S8. android system is standing strong on 2nd place
    10-12-2018 03:04 AM
  1. Bug: Apps opening by themselves non-stop issue on Pie
    By acfan in forum Essential Phone
    Last Post: 09-16-2018, 03:24 AM
  2. Overnight battery drain s6
    Last Post: 09-15-2018, 06:17 AM
  3. How do i put a signature in, my text messages on my samsung galaxy 7
    Last Post: 09-15-2018, 05:14 AM
  4. Can the note 9 shoot raw video?
    Last Post: 09-15-2018, 04:39 AM
  5. Replies: 0
    Last Post: 09-15-2018, 12:30 AM
