1. Samsmome's Avatar
    Since yesterday afternoon I have not been able to use my edge panel with sliding my finger across it. I can make it pop out when I use the spen. Did I change something by accident??? Did something change on its own??? Anyone know how to fix this???
    Any and all help would greatly be appreciated ๐Ÿ˜™
    09-16-2018 11:59 AM
  2. johnmcc0710's Avatar
    Go in to settings and make sure the Edge panel is turned on. If it is on turn it off then on again.
    09-16-2018 07:05 PM
  3. Samsmome's Avatar
    Yeah, I tried that. Still does it. Even shut down the phone.
    Last randomly I was able to side swipe the edge.
    09-17-2018 10:45 AM
  4. johnmcc0710's Avatar
    So you have it back?
    09-17-2018 12:37 PM
  5. Samsmome's Avatar
    Still does it randomly. Thinking it might be due to the screen protector. ๐Ÿ˜
    09-18-2018 06:24 AM
  6. johnmcc0710's Avatar
    Try it without the screen protector. I couldn't type well with one on mine.
    09-18-2018 05:57 PM
  1. Why am I not getting text notifications on my Huawei P20?
    Last Post: 07-13-2019, 05:01 PM
  2. Why can't I play vidoes that were downloaded from my Samsung Galaxy S5 to my pc?
    Last Post: 09-16-2018, 11:38 AM
  3. Why will my Galaxy s5 only accept the first 3Gb of mapping from Memory map
    Last Post: 09-16-2018, 11:17 AM
  4. Why my android tablet losing wifi connection?
    Last Post: 09-16-2018, 10:59 AM
  5. I want to update android 4.4.2 but I can not update .
    Last Post: 09-16-2018, 10:34 AM
