    My note 8 works perfectly fine asides from when it's charging. Once I connect the cable, the screen dims (as it usually does) and begins to glitch with use. When I hold it upright or turn it left and right, the screen brightness is uneven in some parts. It glitches like an old TV struggling to get the signal.
    10-24-2018 09:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does that happen with any charging cable, or only a certain one? I'd suspect a problem with either the cable or the port. Is the phone still under warranty?
    10-25-2018 08:03 AM
  3. Yellowpavement's Avatar
    It happens with the fast charger the phone came with. It's the only one I use. And it is. Do you think I should take it in?
    10-25-2018 10:22 AM
  4. B. Diddy's Avatar
    As long as it's under warranty, it's probably worth contacting Samsung about this.
    10-25-2018 10:25 AM
  5. Mooncatt's Avatar
    I'd recommend trying another USB cable first. They do go bad fairly often and I have seen them cause screen issues because of it. If nothing else, they are cheap and it's good to have a spare anyway. I'd hate to see you go through the hassle of warranty claims if that's all it is.
    B. Diddy likes this.
    10-25-2018 10:31 AM
  6. km04's Avatar
    If nothing else, this could help with diagnosing the issue. And if it is the cable, then you aren't without your phone for a few weeks.
    10-28-2018 05:45 AM
  1. Replies: 3
    Last Post: 10-25-2018, 03:57 PM
  2. Why is my gs4 not sending emojis?
    Last Post: 10-25-2018, 03:54 PM
  3. Go sms settings will not work on my galaxy s7.
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 10-25-2018, 11:38 AM
  4. Whats with the apps popping up on my s8?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 10-25-2018, 08:07 AM
  5. Why did my phone layout change?
    Last Post: 10-25-2018, 08:04 AM
