    Turned on my phone, went to check my email and a message came up saying "system UI isn't responding". Now my phone won't do anything.
    I have a galaxy note8 please help!
    11-15-2018 07:44 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it persist after a reboot? If you're unable to reboot using the normal method, then press and hold Power and Vol Down for about 20 seconds to force a shutdown. If the problem keeps happening, see if it goes away in Safe Mode: https://support.t-mobile.com/docs/DOC-36242. If it does go away, then something you installed is probably causing the instability -- you'd have to uninstall apps one by one until the problem stays away.
    11-15-2018 01:18 PM
  1. Android 5.0 update issue for my Galaxy s5?
    By donnylafave in forum Samsung Galaxy S5
    Last Post: 11-15-2018, 01:21 PM
  2. Replies: 1
    Last Post: 11-15-2018, 01:19 PM
  3. Replies: 1
    Last Post: 11-15-2018, 12:06 PM
  4. Duplication in Messenger, how can I stop it
    Last Post: 11-15-2018, 09:05 AM
  5. Galaxy note 10.1 2014 ed P600
    Last Post: 11-15-2018, 05:45 AM
