1. kingfamily's Avatar
    My son and I are both on the same AT&T Unlimited Data plan. He has a Note 4 and I have a Note 8. I am trying to setup aWiFi hotspot for a laptop computer. My son's Note 4 connects to the WiFi hotspot created by my Note 8, but the laptop can't "see" it. Strangely enough though, the same laptop connects to his WiFi hotspot, which was created with the Note 4.
    Why would a laptop connect to the Note 4, but not the Note 8? Obviously my Note 8 is creating the Hotspot because we can connect to it with his Note 4.
    Had the same issue a month or so ago with my sister-in-law's laptop. Her laptop wouldn't "see" my Note 8 a but connected to her Apple iPhone. Yet, I was able to connect my Android Tablet to the Note 8 Wifi hotspot at that time.
    Any suggestions would be greatly appreciated.
    12-06-2018 07:31 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Check the hotspot settings -- is it set to broadcast on 5 GHz? If so, are you sure your laptop's wi-fi is compatible with 5 GHz, or only 2.4 GHz? https://support.t-mobile.com/docs/DOC-36235
    12-06-2018 07:39 PM
  3. kingfamily's Avatar
    I'll have to check on that. Never crossed my mind. Thanks for the input.
    12-06-2018 08:03 PM
  4. kingfamily's Avatar
    Just checked. It was set to 5 GHz. Once I unchecked the 5GHz box, it worked! Been looking for this all day. Thanks!
    B. Diddy likes this.
    12-06-2018 08:06 PM
  1. Micro SD card not working even after formatting
    Last Post: 12-07-2018, 02:45 AM
  2. Photos not saving to SD
    By rebus66 in forum Samsung Galaxy Note 8
    Last Post: 12-06-2018, 07:40 PM
