1. Blaze4Eva's Avatar
    Saw this icon and disabled everything and read all notifications and still it remains. Normally call notifications appear on the left side but this is on the right side next to my WiFi connection and I don't know what it is (picture attached)
    Attached Thumbnails Unidentified call icon on top Right of samsung note 8-20181209_085120.jpg
    12-09-2018 02:55 AM
  2. methodman89's Avatar
    Did you check voice mail?
    12-09-2018 04:34 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! The shape seems to be related to a SIM card. Is it a dual SIM phone?
    chanchan05 and Blaze4Eva like this.
    12-09-2018 02:09 PM
  4. fredd17's Avatar
    Not sure what it is but my assumption is that it's your "phone" for making calls is turned on? meaning like the other icons in the picture. battery, silent mode, alarm, WiFi and so forth.
    Blaze4Eva likes this.
    12-09-2018 08:03 PM
  5. chanchan05's Avatar
    OP's got a dual SIM phone. The square around the signal triangle bar on dual sim phones only appear when there are two signal bars with the square around the primary sim signal.
    That icon refers to what SIM the OP has as primary. Typically it should be a "1" or "2" in that symbol though. You can select icons used in Settings>Connections>SIM Manager>Tap on the SIM you want to change icons for>Icons.
    Source: I've owned dual SIM Samsungs since 2014 since all models they have in my country are dual SIM.
    B. Diddy and Blaze4Eva like this.
    12-09-2018 08:51 PM
  6. Blaze4Eva's Avatar
    Sorry for the late response but I did not receive notifications that anyone had replied to my question and I had forgotten my password. I just had my screen repaired and they put the sim cards in the wrong slots. Yes it is a dual sim phone and in turning the sims on and off to fix connection problems the symbol went off. Thank you all for confirming and just in time as I was about to uninstall my favourite apps in the fear that I had picked up a trojan or a virus (watching alot of Law & Order). Anyways thank you all for your help and confirmation.
    B. Diddy likes this.
    12-15-2018 05:39 PM
  1. Replies: 2
    Last Post: 12-10-2018, 06:09 AM
  2. Does a Samsung s8 plus from UAE really have a different screen?
    By Laurence Turner in forum Samsung Galaxy S8 & S8+
    Last Post: 12-09-2018, 05:26 AM
  3. Best/Any Good Repl. Batt. (& rant on same:))?
    By daninbluemd in forum Samsung Galaxy Note 4
    Last Post: 12-09-2018, 12:59 AM
  4. Samsung note8 top screen doesnt work
    Last Post: 12-09-2018, 12:56 AM
  5. microphone stopped working while recording voip calls
    Last Post: 12-08-2018, 11:52 PM
