    My time in the weather widget is not running at the right time and not the same in the phone time in my note 8...how can i fix this?kindly please help me to make this run at the right time same with the phone time...i try everything but it didnt work at all...anyone knows the solution?thanks
    12-10-2018 10:33 AM
  2. bbgpsuser's Avatar
    I would suspect that your weather widget is set to a location not in your time zone.
    jimd1050 likes this.
    12-10-2018 02:33 PM
  3. jimd1050's Avatar
    Look for a setting in the "Widget Settings" that says something like "Follow me" or "Use my Location" for "Time Zone" or "Location", like bbgpuser stated, that is more than likely your issue. The Widget is stuck on a fixed location when you want it to follow you wherever you travel - that way, it uses the phone's GPS to determine where it is and gives you the time, date and weather for that location!
    12-10-2018 02:39 PM
  1. LG V20 poor battery life? It's not the phone.
    By sanford12 in forum LG V20
    Last Post: 12-12-2018, 06:25 PM
  2. samsung s7 edge google sign in
    By Paulgan54 in forum Samsung Galaxy S7 edge
    Last Post: 12-10-2018, 01:20 PM
  3. Error in transferring photos to PC from Samsung A5
    Last Post: 12-10-2018, 01:06 PM
  4. i just want to know why my phone is purple and black
    Last Post: 12-10-2018, 12:32 PM
  5. Replies: 0
    Last Post: 12-10-2018, 10:10 AM
