1. WingLT's Avatar
    For some reason I can't set custom ringtones or notifaticans on my Note 8. Started happening a few months ago. I tried using the Zedge app, and even tried putting them in the Ringtone and notification folders on internal storage and it still won't work... It keeps reverting back to current themes settings. It never did this before prior to a few months ago.... Is there a fix for this? Is anyone else having this problem?
    01-11-2019 11:41 AM
  2. NiffiIsenguard's Avatar
    just save it to the Zedge library then select from there when you go to change. i.e pick a source> Zedge found it fixed the problem 100%
    01-13-2019 03:38 PM
  3. WingLT's Avatar
    Sorry it's still doing it. It was the first thing I tried. Then I tried putting the stuff in the Ringtones and Notification folders and that didn't work either. I have found out that it's a known issue for Oreo. Hopefully with the new upgrade to Pie will fix this...
    01-17-2019 04:45 PM
  1. problem download location chrome sd card
    Last Post: 01-15-2019, 09:30 AM
  2. Text Message Count is Off
    Last Post: 01-11-2019, 11:52 PM
  3. What is bmwgroup on my android
    Last Post: 01-11-2019, 11:47 PM
  4. Cant take picture with Pixel 2 on Manual time/date setting?
    By AF2018 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 01-11-2019, 03:49 PM
  5. Replies: 1
    Last Post: 01-11-2019, 11:14 AM
