1. JRWeitlauf's Avatar
    Will a Samsung Note 8 mirror to a Google Chromecast device?
    Can I use a USB C to HDMI adapter to connect to the projector?
    01-18-2019 10:17 AM
  2. SpookDroid's Avatar
    Yup to both. You'll need the Home app to mirror to a Chromecast, but it works. The Note 8 also supports video-out through USB-C so you're good (and with better quality/sync than wireless mirroring) that way too.
    Just remember, for Chromecast to work, BOTH devices need to be in the same WiFi network or router. There is no Wi-Fi Direct option for Chromecast.
    01-18-2019 10:35 AM
  3. anon(7901790)'s Avatar
    It'll also mirror to Miracast and most smart TVs that are WiFi capable. I carry a Microsoft Wireless Display Adapter whenever I travel.
    The same applies that SpookDroid said. You must be on the same WiFi network.
    01-18-2019 04:06 PM
  4. SpookDroid's Avatar
    Not necessarily for Miracast. The protocol does allow for WiFi-Direct connections (just as mirroring does), so if the TV or dongle supports it (which the Chromecast doesn't), you can connect directly without a router. But things that don't support that (like Roku or some TVs, too), then yeah, a router in the middle is required to put all devices in the same network.
    01-20-2019 08:28 PM
  1. Replies: 93
    Last Post: 02-28-2019, 09:14 AM
  2. Replies: 4
    Last Post: 01-18-2019, 10:31 PM
  3. Connection Issues for the past 2 months
    Last Post: 01-18-2019, 12:04 PM
  4. How to access data copied to clipboard for S7 phone
    Last Post: 01-18-2019, 10:40 AM
  5. Replies: 1
    Last Post: 01-18-2019, 10:37 AM
