1. JnEricsonx's Avatar
    Just wondering before I get one, since I'm soon to get a Note 8. Or is there a battery case for the Note 8 that you might suggest?
    05-22-2019 07:34 PM
  2. km04's Avatar
    I have tht case and it does not work with the wireless charger all the time. It is finicky as best.
    mdZX likes this.
    05-22-2019 09:13 PM
  3. z0ove's Avatar
    I've the Defender version and it works perfectly. No problems at all
    mdZX likes this.
    05-23-2019 08:48 AM
  4. yarnsrj's Avatar
    I have the regular as well as the Fast charge wireless chargers and they work fine with my OtterBox defender case. Just be mindful of your phone's placement to insure it's charging.
    05-23-2019 09:46 AM
  5. Hexonxonx's Avatar
    If you get the convertible charger, the one that can lay flat, you will not have any trouble.
    I gave up using that case after about six months because it became stretched out after taking it off 4-5 times.
    05-26-2019 12:03 AM
  6. yarnsrj's Avatar
    Well whatever you decide, I love the OtterBox case. Been using mine for over a year and a half without issues. I've only removed it maybe once or twice to try a different color and to change the screen protector. Charges fine. Funny thing is this is the first Note phone that I actually used the OtterBox case on, as I didn't like the bulkier footprint on my Notes 3 and 5.
    05-26-2019 07:25 AM
  7. JnEricsonx's Avatar
    I'm just used to using Otterbox on my last two phones due to them being case and screen protector all in one. Now that you need a seperate screen protector for the Note 8, I'm just trying to get all info before I drop 400 odd bucks on the phone then add in all the add-ons.
    05-26-2019 02:46 PM
  1. Can i take screenshots on my gs10+ without using the power and volume down button?
    By Bethany Harding1 in forum Samsung Galaxy S10 & S10+
    Last Post: 05-24-2019, 05:51 PM
  2. Any smartphone suggestion that doesn't look like a brick in the hand?
    Last Post: 05-22-2019, 07:21 PM
  3. Why does my ubication not work on strava on the watch?
    By Android Central Question in forum Samsung Galaxy Watch Active
    Last Post: 05-22-2019, 04:07 PM
  4. Why does my ubication not work on strava on the watch?
    Last Post: 05-22-2019, 03:48 PM
  5. Replies: 0
    Last Post: 05-22-2019, 03:22 PM
