1. Tanooki2's Avatar
    I was traveling this week and upon landing, I turned off Airplane Mode and my Note 8 was very laggy for about 30 seconds and froze. I held down the power button to restart and it would not boot back up. It is completely unresponsive. I took it into Verizon and they tried the various soft and hard reset button combinations to no avail. My phone was stock, Pie, no new apps, and had about 90% charge.
    Any thoughts on what may have occurred and whether or not it may be fixable?
    06-06-2019 10:12 AM
  2. Rukbat's Avatar
    That depends on what happens if you try looking at it with adb. If there's no response, something on the motherboard could have gone bad. If there's a response, booting into bootloader with adb (adb reboot bootloader) should bring the phone to download mode, from which you (or they) can reflash the ROM. Most Verizon company stores have a repair department (ell, a little room) in the back that should have adb and a Samsung driver already installed on at least one computer. Independent Verizon stores usually have a computer set up for that too.
    06-06-2019 01:34 PM
  1. Switch from a Note 9?
    By Knightmayre90 in forum Sony Xperia 1
    Last Post: 06-09-2019, 05:26 PM
  2. Can't set custom alarm ringtone after upgraded to androir 9
    By Android Central Question in forum Android Pie
    Last Post: 06-06-2019, 10:22 AM
  3. Can't set custom alarm ringtone after upgraded to androir 9
    Last Post: 06-06-2019, 01:53 AM
  4. In M20 after pie update always on display is not available why
    Last Post: 06-05-2019, 03:25 PM
  5. Can't turn off screen unlock notification after update
    Last Post: 06-05-2019, 10:58 AM
