1. Super Dave426's Avatar
    I threw my Note 8 on the wireless charger at 50% and when I woke up it was down to 21%. Thought it might be the charger so I threw it on the Samsung one that came with the phone after a reboot and it dropped 2% in 10 minutes, faster discharge than if I just let the phone sit on the table. Any ideas that might have happened?
    08-04-2019 07:43 AM
  2. z0ove's Avatar
    i think fast charging mode is not working. Try changing charger cable for a better one and if that doesn't work try other charger
    GL!
    08-04-2019 10:31 AM
  3. B. Diddy's Avatar
    Are you sure the wireless charging is working at all? Do you get any indication that it's charging? Does it charge normally when you plug it in?
    08-04-2019 01:28 PM
  4. Super Dave426's Avatar
    It did light up and say it was charging, but not any more. The charger works fine with my wife's Note 8 but mine doesn't even turn on the light any more. Guess I'm done wireless charging with this phone.
    08-04-2019 07:17 PM
  5. ScKalbe's Avatar
    When in doubt reboot
    08-05-2019 12:30 AM
  6. me just saying's Avatar
    only time my note 8 did this was when something was running in the background. It was after an update but it could have been just a coincidence. I rebooted, deleted system cache and it was okay after that.
    08-05-2019 05:17 PM
  7. Super Dave426's Avatar
    I've done all that and nothing has changed, I always charge my phone fully and turn it off every night and shelve it. Today when I turned it on it was at 92% so something must be wrong with the phone.
    08-06-2019 04:51 AM
  8. me just saying's Avatar
    did you go into settings and check device care? maybe something there will give a hint as to the problem.
    08-06-2019 03:42 PM
  9. Super Dave426's Avatar
    I also realized that Samsung Pay isn't working anymore, must be a hardware issue. I will try a factory reset in the future and if nothing changes I might look at a Pixel 4.
    08-11-2019 02:17 PM
  1. Battery randomly dying
    By 2crazy98 in forum Google Pixel 3a & Pixel 3a XL
    Last Post: 08-04-2019, 01:50 PM
  2. Droid turbo batterys hot think spam or something in phone
    Last Post: 08-03-2019, 01:34 PM
  3. Replies: 4
    Last Post: 08-03-2019, 12:58 PM
  4. Samsung slideshow keeps the screen active and wears the battery down quickly.
    Last Post: 08-03-2019, 09:47 AM
  5. I didn't charge my new S7 the recommended 5hours. Battery life is terrible.
    Last Post: 08-02-2019, 04:37 PM
