Originally Posted by
Galactic Zoo I answered your earlier post. It is only a PC requirement.
Safely removing device is not required for Win8 and newer.
Android Central Question My usb cable is connected to Win 10 PC at once end and connected to Note 8 at the other end. After I transferred some photos to PC I want to disconnect phone from PC.
How can I safely remove note 8 device?
Why there is no safely remove device option for note 8?
Thanks
Once you're done copying what you need, just unplug it. It'll be fine. The "Safely remove device" function is obsolete.
