11-19-2019 03:33 PM
30 12
tools
  1. Rukbat's Avatar
    I can't help you with the hacking (that's difficult enough to do hands-on), but to see if your phone's camera can see IR, aim a TV remote at it (while the camera app is running, of course) and press a button. If the camera can see IR, you should see the LED flickering (which you can't see with your eye, because it's IR). Most phones can "see" into IR.
    That doesn't mean that you got a picture of something that's transparent in visible light but visible in IR. If it were invisible except in IR, it would look black in visible light, not transparent.
    Mhal201945 likes this.
    11-15-2019 03:14 PM
  2. anon(7901790)'s Avatar
    I've taken IR photos and that doesn't look like any IR photo I've ever taken or seen.
    11-18-2019 10:03 PM
  3. Mhal201945's Avatar
    Thanks for this feedback. It is very useful.
    11-19-2019 10:24 AM
  4. Mhal201945's Avatar
    For those concerned, the hard drive on my laptop is being wiped and all programs are being reinstalled.
    11-19-2019 10:27 AM
  5. anon(7901790)'s Avatar
    I'm confused. What does wiping your laptop's hard drive have to do with the Samsung Galaxy Note 8, specifically its camera?
    11-19-2019 03:33 PM
30 12
  1. Note 10 Android 10 Beta: Issues and First Impressions
    By Mike Dee in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 12-21-2019, 02:25 AM
  2. Will this Note 10 deal get any better?
    By cowboy3008 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-22-2019, 10:13 AM
  3. Replies: 3
    Last Post: 11-16-2019, 09:49 PM
  4. Replies: 1
    Last Post: 11-13-2019, 04:47 PM
  5. Will the Pixel 3 XL be good for another 2 years?
    Last Post: 11-13-2019, 04:11 PM
