11-19-2019 04:33 PM
30 12
tools
  1. Mhal201945's Avatar
    Does the Note 8 rear camera filter infared light or can it take infared light and convert it to a image within a video? What is the known electromagnetic range of the rear camera? Does it only filter visible light and convert it to image?
    11-13-2019 05:51 PM
  2. anon(7901790)'s Avatar
    Short answer: Yes it does.
    Almost all digital cameras have an IR filter installed.
    Both CMOS and CCD sensors are sensitive to IR. IR affects image quality so sensor manufacturers install an IR filter on the sensor.
    This can explain it better than I can as to why.
    https://www.whatdigitalcamera.com/te...xplained-11457
    Mhal201945 likes this.
    11-13-2019 05:55 PM
  3. Mhal201945's Avatar
    Thanks!
    So why do people say you can see IR from a TV remote when you view it with your cell phone?
    11-13-2019 06:03 PM
  4. anon(7901790)'s Avatar
    Thanks!
    I've not seen that. I'll have to give it a try.
    11-13-2019 06:11 PM
  5. Mhal201945's Avatar
    The reason I am asking is because I took some video, short video, like 4-5 seconds and I didn't see a human like form while taking the video but it appears clearly in the video. It has a lot color. Brown, grey belt, bright illuminated head with facial profile. I want to know what IR conversion would lok like digitally. Would all these colors appear? I think someone edited my video and I am looking for answers.
    11-13-2019 06:14 PM
  6. Mhal201945's Avatar
    Here is a screenshot from the video.
    Attached Thumbnails Does the Note 8 rear camera filter infared light?-screenshot_20190922-214404_video-player.jpg   Does the Note 8 rear camera filter infared light?-20191022_202602.jpg   Does the Note 8 rear camera filter infared light?-screenshot_20191021-095204_video-player.jpg
    11-13-2019 06:16 PM
  7. anon(7901790)'s Avatar
    I honestly don't have any answers as to how that happened.
    I have taken IR photos with my Canon DSLR, but I an IR filter on my lens and had to aim and focus it before putting on the filter.
    I just tried the IR remote experiment in a dark room and didn't see anything.
    11-13-2019 06:18 PM
  8. anon(7901790)'s Avatar
    Could you indicate where? I'm not seeing anything.
    11-13-2019 06:20 PM
  9. Mhal201945's Avatar
    I just posted three photos of it. It looks real as you and me. That is what is so puzzling. It has a brown coat, black belt, white face. It is the focus of the screenshot. People keep looking for shadows or translucent forms. This is not that.
    11-13-2019 06:22 PM
  10. anon(7901790)'s Avatar
    IR wouldn't be in color.
    11-13-2019 06:23 PM
  11. Mhal201945's Avatar
    Thanks! If IR wouldn't be converted to color this could possible be a video edit. Do you know anything about codec information?
    11-13-2019 06:25 PM
  12. anon(7901790)'s Avatar
    This is what IR images look like. This is after processing in an image editor.
    11-13-2019 06:26 PM
  13. Mhal201945's Avatar
    The reason I am asking about codec information is because when I play the video and look at the video when it is playing, the codec information shows unknown, unknown, while the EXIF shows AAC, and H.264. Could someone edit the EXIF info?
    11-13-2019 06:28 PM
  14. anon(7901790)'s Avatar
    Yes. EXIF can be changed.
    11-13-2019 06:29 PM
  15. Mhal201945's Avatar
    how can I find out what created the video? I really need to know if the video was edited and that human like form was put in the video.
    11-13-2019 06:31 PM
  16. Mhal201945's Avatar
    a friend of mine The Happy Scientist (small time celebrity) put the video in video software program and used motion tracking on it. He said the motion tracking wanted to put the object closer than it appears. Does this mean anything in terms of video editing?
    11-13-2019 06:33 PM
  17. anon(7901790)'s Avatar
    That I don't have an answer for. You can try to find forensics type software for analyzing video.
    11-13-2019 06:33 PM
  18. anon(7901790)'s Avatar
    You'd have to ask him what software he used. But, yes, you can change perspective post video capture.
    11-13-2019 06:35 PM
  19. Mhal201945's Avatar
    Here is the video. If you looked at it could you tell me anything about video editing? I would be very grateful if you could. I fear I have been hoaxed. https://www.dropbox.com/s/ueymp9r6wr...22415.mp4?dl=0
    11-13-2019 06:35 PM
  20. anon(7901790)'s Avatar
    Yeah. It looks like you've been had.
    Looks like you just need to return the favor.
    11-13-2019 06:47 PM
  21. Mhal201945's Avatar
    I don't know who it was. They are sophisticated though. A few weeks after this video he or she took control of my cursor while I was doing some updating World of Tanks and they continued to open all of the programs on the task bar. They did this for 6 minutes. Irecorded it and looked at the video closely and I noticed they tried to edit a file name using F2.
    11-13-2019 07:07 PM
  22. Mhal201945's Avatar
    They tried to make it look like a ghost or poltergeist but the F2 file name edit gave the game away. I changed all my passwords and made my network password very strong.
    11-13-2019 07:09 PM
  23. Mhal201945's Avatar
    What can you see that gives away video editing? To me it looks like a tranasposed image because if you look at the space between the arm and body, you don't see the area behind the entity.
    11-13-2019 07:10 PM
  24. anon(7901790)'s Avatar
    If that is the case, you need to scan your system for malware. You haven't hoaxed. You've been hacked. Somebody taking control of your system remotely is no laughing matter.
    11-13-2019 07:19 PM
  25. Mhal201945's Avatar
    I contacted Mindak, my company's tech support, and we ran programs looking for malware. Two threats were removed but we didn't know what they were. The tech guy thought it was my mouse just going haywire. I did some research and I thought it was a mouse jacking. However, they could have hacked the remote access program tech support uses to work on my computer when needed. But, that program wasn't being used during the cursor movement.
    anon(7901790) likes this.
    11-14-2019 11:45 AM
30 12
  1. Note 10 Android 10 Beta: Issues and First Impressions
    By Mike Dee in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 12-21-2019, 03:25 AM
  2. Will this Note 10 deal get any better?
    By cowboy3008 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-22-2019, 11:13 AM
  3. Replies: 3
    Last Post: 11-16-2019, 10:49 PM
  4. Replies: 1
    Last Post: 11-13-2019, 05:47 PM
  5. Will the Pixel 3 XL be good for another 2 years?
    Last Post: 11-13-2019, 05:11 PM
