1. JnEricsonx's Avatar
    I guess it's kind of hard to tell for me, my phone is probably about 1.5 years old as I got it earlier this summer from someone else who'd had it a year, and I'm just wondering how can I tell if the battery is no longer as good, or not. I know games are battery hogs, but I'd think running MSF with Wifi on vs having 4g running would slow down the drain somewhat. Out of idle curiosity, anyone know what the average cost to replace a Note 8 battery is? I miss being able to buy a replacement battery, pop off the back, and bam.
    12-13-2019 08:52 PM
  2. mustang7757's Avatar
    If you want to keep the water resistant go to ifixit or Samsung probably be around 150 to 280 you could call them to find out , it will be cheaper at any other 3rd party repair shop but won't have the water resistant .
    Laura Knotek likes this.
    12-13-2019 08:56 PM
  3. B. Diddy's Avatar
    Try installing AccuBattery and running the battery health analysis.
    12-13-2019 09:35 PM
  4. JnEricsonx's Avatar
    Hopefully that's a simple, yes/no type readout from it?
    12-13-2019 10:00 PM
  5. B. Diddy's Avatar
    No, it gives you a percentage of the battery health. https://accubattery.zendesk.com/hc/e...-health-screen
    12-13-2019 11:32 PM
  6. JnEricsonx's Avatar
    Ok. I guess I should let the battery run down some then, before charging it up for it to get a better read?
    12-13-2019 11:50 PM
  7. B. Diddy's Avatar
    No, I wouldn't recommend that -- you should generally avoid deep discharges of a battery if you can avoid it. Doing that frequently can accelerate a battery's deterioration (and if the previous owner did this frequently, that could be a potential reason for your current battery's state). AccuBattery can give you a more accurate reading of the battery health after multiple charging cycles, so you just have to keep it installed for several days or 1-2 weeks, so that it has more data points.
    12-14-2019 12:15 AM
  8. JnEricsonx's Avatar
    Oh, trust me, by running it down some, I mean just let it sit, use it, etc, and when I hit around 50-60% battery then charge it. I NEVER let my phone go that low unless I'm utterly not in a position to charge it.
    12-14-2019 12:41 AM
  9. B. Diddy's Avatar
    Oh ok, go for it. But personally, I'd just use it normally for several days, then run the battery health analysis. It should be able to come up with a good reading by then.
    12-14-2019 01:24 AM
  1. Adding a language to the keyboard
    By oddstray in forum Pixel C
    Last Post: 12-22-2019, 12:54 AM
  2. Replies: 11
    Last Post: 12-14-2019, 05:22 PM
  3. Samsung Galaxy S6: Home and Power button stop working intermittently
    Last Post: 12-14-2019, 04:32 PM
  4. Can not answer phone by swiping i
    Last Post: 12-14-2019, 02:00 PM
  5. My RCS in Samsung msgs not working
    Last Post: 12-13-2019, 08:45 PM
