1. DroidKnight3000's Avatar
    Has anyone found a good reliable solution for protective solutions compatible with Gear VR and by this I mean the following...
    1) Protect reliably, either case and screen protector or flip case or other?
    Trying to avoid scratches and general drops. A lanyard option is probably a good one..
    2) Compatible with note 8 VR and new adapter if anyone has it yet? I.e a case that comes on and off easily and if not flip case does the new adapter work with Whitestone Dome screen protector? I've heard issues with the VR adapter popping up the glass protector. No idea what new one will be like. Wondering if a dremel drill is still required!
    09-06-2018 03:07 AM
  2. DroidKnight3000's Avatar
    Can someone move this to the Note 9 thread. I didn't have the option on the drop down.
    09-06-2018 05:05 AM
  1. Is it my battery or my phone?
    Last Post: 09-06-2018, 02:19 PM
  2. Replies: 1
    Last Post: 09-06-2018, 01:08 PM
  3. What is lge.launcher3 and what is it usted for
    Last Post: 09-06-2018, 06:34 AM
  4. What is lge.themesquare and what is it used for
    Last Post: 09-06-2018, 01:50 AM
  5. use G7 as a DAC for PC
    By yurivr in forum LG G7 ThinQ
    Last Post: 09-05-2018, 11:36 PM
