1. worldsoutro's Avatar
    Anyone have a good recommendation on a wireless stand? The Samsung ones are pretty expensive.
    09-17-2018 09:08 AM
  2. jeetu4444's Avatar
    check Amazon USA if u live there many options ...
    amyf27 likes this.
    09-17-2018 02:18 PM
  3. amyf27's Avatar
    You can check the Marketplace forum on Android Forums - people sell used products there. I recently sold a wireless charge/mount there. You can get really good stuff for much less than retail.
    09-26-2018 04:46 AM
  4. Angus66's Avatar
    I purchased this one a couple of years ago for my S7 Edge & it works great with my Note 9:
    https://www.amazon.com/Seneo-Wireles...cUvbUpU6390000
    I use it with the charger that came with the Note 9...
    Beansr519 likes this.
    11-04-2018 10:28 AM
  1. Magnetic Adsorption Case for Samsung Galaxy Note 9 Glass + Built-in Magnet Case Metal Cover
    By jeetu4444 in forum Samsung Galaxy Note 9 Cases & Accessories
    Last Post: 10-14-2018, 12:03 PM
  2. Replies: 1
    Last Post: 09-17-2018, 08:51 AM
  3. Which is the best (quick)charging cable for the Nokia 8?
    By wp patrick in forum Ask a Question
    Last Post: 09-17-2018, 08:07 AM
  4. Replies: 0
    Last Post: 09-17-2018, 04:45 AM
