1. RyanRC's Avatar
    Hello All
    My company just got me a Note 9 and I am trying to find a belt clip leather pouch that will take it with a Otterbox Defender over it.
    I purchased this one from Amazon: https://www.amazon.com/gp/product/B0...cUvbUpU6558367 …as it said it was oversized for it, but when I got it I found it to be way to tight and while perhaps it might wear in over time, given how tight it is I think it’s going to take really long time.
    Amazon does list this one as working with the Otterbox: https://www.amazon.com/Galaxy-Note-B...cUvbUpU6558367 …but even if it does this one has lots of bad reviews of the clip breaking off very soon and since I work and use this phone in a pretty physically demanding job that probably would get old soon.
    At any rate, thought would post here to see if anyone had any better sources for something along the same setup.
    Thanks for any help
    06-04-2019 07:27 PM
  2. Mike_Luchia's Avatar
    This is the largest belt clip case I have found https://forums.androidcentral.com/e?...token=qXuGziNR but haven't tried it with my Otterbox yet. That being said it does fit my ArmadilloTec and UAG fine.
    06-05-2019 08:40 AM
  3. Mike_Luchia's Avatar
    This is the largest belt clip case I have found https://forums.androidcentral.com/e?...token=HMzlbDMZ but haven't tried it with my Otterbox yet. That being said it does fit my ArmadilloTec and UAG fine.
    Just an update, the Otterbox Defender fits in the ToughTester case I posted no problem. The Degender is pretty much the biggest case I know of so anything else should fit in it fine.
    06-08-2019 04:20 PM
  4. camedenliving's Avatar
    I meant a holster works better
    You need extra efforts to take the phone out of a pouch!
    06-10-2019 02:52 PM
  5. Mike_Luchia's Avatar
    Not sure what one you're using but I can take my phone out of the ToughTested in under a second without any effort.
    06-10-2019 04:13 PM
  1. I am looking for a smartwatch for huawei p20 pro
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 06-20-2019, 03:00 PM
  2. Getting a Note 8, how are these included accessories?
    By JnEricsonx in forum Samsung Galaxy Note 8
    Last Post: 06-17-2019, 09:42 AM
  3. Best size for printing of pictures
    Last Post: 06-05-2019, 03:44 PM
  4. When selecting theme for home screen, there is no date, time, weather.
    Last Post: 06-04-2019, 06:48 PM
  5. How can I factory reset my Note 9 with a blank cracked screen?
    Last Post: 06-04-2019, 05:32 PM
