AT&T Note 9 upgrade after PIE
ciyoj
12
Hi @mustang7757,
I have an AT&T Galaxy Note 9 (SM-N960U)
I am using it in Asia outside of US so i think its unlocked
I was on (Android version: 8.1.0) N960USQS1ARL2 , so i wanted to upgrade to Android version: 9.0 (N960USQU1CSAA)
I downloaded the update from firmware.science and applied the update via SD Card method.
I am now successfully upgraded to PIE.
My question is how do i move forward from here now ?
As you can see on the AT&T they are listing almost 10 more updates after (N960USQU1CSAA)
https://forums.androidcentral.com/e...Samsung%26model%3DSamsungN960U&token=9h97LxOt
Can you guide how to install these further updates ?
Your help would be much appreciated.
Best Regards.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
This is the steps :
Windows computer needed
Latest Odin can Google it and download should be 3.13.1 or 3.14.1
Download samfirm v0.4.1 tool , extract it with 7zip.
You will extract files for Odin once download with 7zip and will do same for firmware with 7zip .
There will be 4 files after you extract the firmware
BL
AP
CP
CSC
Each of those files will go in Odin when you open to the corresponding slots
BL
AP
CP
CSC USE HOME CSC FIILE TO SAVE DATA
Home data slot dont put nothing
connect your phone with cable to computer , once the files are in its slots hit start, once done you'll see pass in Odin and it will reboot
My picture shows circle on what you need to do
Put your model number,region select check for updates , then download the Rom , extract the Rom with 7zip
Make sure phone is in download mode by holding power/bixby/volume down button sane time after rebooting the device then select continue.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
The other thing to point out samfirm tool doesn't give Att firmware , so you need to put your device model and tmobile for region , use TMB so you can be on the latest.
Only one I know who can get Att firmware is @Ruben Ocasio but its up to him if wants to give or not ...
But the tmobile firmware will work .
ciyoj
12
Hi,
Thanks for this information.
I have some questions:
So does this T-Mobile version works perfectly fine with ATT Note 9 ?
Will my local carrier still be working after this update ?
How much time would it take for this process to complete ?
I can just skip all the updates and just flash the latest firmware ?
Regards
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
Hi,
Regards
All carriers firmware are universal, the problem is is if you flash tmobile and att is on a different build number you cant get OTA updates when you check software updates in settings , you have to flash new version when security update comes out but it only takes 10 minutes and done .
So you can do this and everything will work fine
ciyoj
12
I don't get any OTA updates anyways as you have to be on an ATT network for that and i am located in Pakistan and using a different carrier.
I am gonna try this out today.
I haven't flashed ever before so a bit scared as well but i am gonna give it a try...
Will let you know after the update (hopefully a successful one )
Thanks
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
Thanks
I understand being scared first time , just read over my direction , and worse thing it will do is not load if you do something wrong , just retry .
Its really easy once u get the hang of it , but let me know
ciyoj
12
1 last question i understand while using odin i can leave user data slot blank.
I will be factory resetting before starting this flashing.
Which CSC file should i use ?
And whats the difference between CSC and HOME CSC
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
Csc will factory reset and home csc will keep data ..you could do either
ciyoj
12
Hi @mustang7757,
I did the flashing procedure it passed successfully on Odin, but after it restarted it is stuck at installing system update on a blue screen.
I am waiting now for like more than 20 minutes.
Any help ?
Thanks
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
Hi @mustang7757,
Any help ?
Thanks
Hi, 20 minutes on blue screen is too long , you see and percentage going up?
samyblaze
