1. Roadhog360's Avatar
    Title. I've heard it works but I need a solid confirmation. My 9's pen broke because it fell out as I dropped it. I need to replace it, and like how the blue Note 8 pen is all blue and has no yellow. I want that as my replacement, will it work as a full replacement?
    04-30-2020 09:48 AM
  2. mustang7757's Avatar
    It might be able write on the screen with it but won't be able to use the Note 9 Bluetooth function. We can get some other members input also.
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    04-30-2020 09:53 AM
  3. mustang7757's Avatar
    04-30-2020 09:55 AM
  4. Roadhog360's Avatar
    Hello. I have had an account but it seems the website had logged me out and there is no indication on the corner of the screen or anything if I am logged in or not. I would like this post to be transferred to my account, please.
    04-30-2020 10:19 AM
  5. me just saying's Avatar
    the 8 s-pen will work on the note 10 so I will assume it will work on the note 9 - just tried it. everything I tried worked. but as a full replacement, nope. there will be things that will not work and I certain would not try storing it in the s-pen slot. depending on how you use the pen, it might be better just to get a replacement.
    04-30-2020 10:36 AM
  6. mustang7757's Avatar
    Ok, done !
    04-30-2020 10:38 AM
  7. Roadhog360's Avatar
    I've heard it fits into the 9 slot just fine, can anyone confirm? And if you recommend a Note 9 pen are there any 100% blue ones out there?
    04-30-2020 11:08 AM
  8. me just saying's Avatar
    a quick forum search found the following
    https://forums.androidcentral.com/sa...-note-9-a.html
    mustang7757 likes this.
    04-30-2020 11:28 AM
  9. L0n3N1nja's Avatar
    All the S pens from the original Note to the Note 10, including all Note tablets, Tab A/S with S Pen, chromebook, and laptop S Pens use the same tech and work on each other.
    04-30-2020 12:32 PM
  10. Roadhog360's Avatar
    That doesn't answer all my questions, hence this thread. There are a lot of "I think"s and missing facts. Either way I see it doesn't charge so I want a blue Note 9 pen now.a
    05-01-2020 08:10 AM
  11. me just saying's Avatar
    you are right, but it did answer one of them, and IMO, the main question.
    05-01-2020 10:23 AM
  12. Roadhog360's Avatar
    Yeah, you're right.
    Anyone know if a completely blue Note 9 pen exists?
    05-01-2020 05:12 PM
  1. AT&T Note 9 upgrade after PIE
    By ciyoj in forum Samsung Galaxy Note 9
    Last Post: 05-03-2020, 05:40 AM
  2. my phone is stuck on the logo and cannot turn on what should i do
    Last Post: 04-30-2020, 12:04 PM
  3. Note 10+ no longer charges wirelessly
    By Larry Covington in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 04-30-2020, 04:02 AM
  4. Photos on my phone that don't belong
    Last Post: 04-29-2020, 06:12 PM
  5. high speed sd card on android phone
    Last Post: 04-29-2020, 05:56 PM
