1. recDNA's Avatar
    My Note 9 is being repaired so I am backing up with smart switch on my Windows computer before doing a factory reset.
    When I get phone back at what point do I use smart switch restore from computer back to phone?
    Do I sign in to Google Gmail first or just connect the completely unset Note 9 back to the computer and run smart switch restore?
    Any tips gratefully accepted.
    08-31-2020 09:59 PM
  2. mustang7757's Avatar
    Sign into everything then connect to smart switch and restore
    Laura Knotek and recDNA like this.
    08-31-2020 10:06 PM
  3. recDNA's Avatar
    Now I'm really stuck - I didn't see your answer and called Samsung. They said to be sure to connect to smart switch BEFORE Google so you don't get duplicate contacts?
    Make any sense?
    09-02-2020 01:14 PM
  4. mustang7757's Avatar
    Make any sense?
    You would have to go after Google sign in to use back up from smart switch, so you can do at that point or after you get on the screen, no duplicate or anything.
    recDNA likes this.
    09-02-2020 01:38 PM
  5. recDNA's Avatar
    So I sign in to Google but refuse auto google back up then connect blank phone to computer with smart switch backup and it will find phone again and restore everything?
    Samsung guy said I would get a smart switch option before phone asked for Google sign in. I never remembered that so I was perplexed by his advice.
    I hope smart switch sets up wear os against so I don't have to reset my Fossil Carlyle.
    09-02-2020 01:44 PM
  6. mustang7757's Avatar
    It will say connection then sign Google then restore from back up then fingerprints, then Samsung sign in
    09-02-2020 02:59 PM
  7. recDNA's Avatar
    Any problem taking the sim out of this Note 9. Shutting it off. Then installing sim in old vzw lg v20 then reversing process tomorrow when I get phone back?
    VZW told me not to because it would lock my phone? I really don't know what they mean but I'm not changing providers anyway.
    I've never tried the sim switch process. Do I still have to activate on line?
    09-02-2020 04:10 PM
  8. recDNA's Avatar
    When do I connect to computer for smart switch back up?
    09-02-2020 04:53 PM
  9. mustang7757's Avatar
    When it ask do you want restore from back up.
    09-02-2020 05:05 PM
  10. recDNA's Avatar
    I long for the good old days when my phones were rooted and a back up backed up absolutely everything!
    mustang7757 and kixfan like this.
    09-02-2020 05:11 PM
  11. Mike Dee's Avatar
    I don't know what you're trying to do but swapping the sim back and forth shouldn't lock a phone. I assume they mean carrier lock.
    09-02-2020 05:15 PM
  12. mustang7757's Avatar
    Samsung cloud, use it while still can
    09-02-2020 05:15 PM
  13. recDNA's Avatar
    I used computer because 15gb isn't even close to my backup needs
    09-02-2020 05:18 PM
  14. mustang7757's Avatar
    Very good point
    09-02-2020 05:19 PM
  15. recDNA's Avatar
    I assume it means carrier lock. I've always been VZW. Always will. Nobody else has good signal in burbs of Boston
    09-02-2020 05:22 PM
  1. Replies: 1
    Last Post: 08-31-2020, 11:47 AM
  2. Replies: 99
    Last Post: 08-30-2020, 01:29 PM
  3. Nova Launcher question on the LGV60
    By Lambertoid in forum LG V60 ThinQ
    Last Post: 08-30-2020, 12:52 PM
  4. Samsung.com return question
    By jtcannonball in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-28-2020, 04:12 PM
  5. Alarm wake to music/snooze question
    Last Post: 08-28-2020, 10:41 AM
