12-12-2020 08:12 AM
32 12
tools
  1. veggie59's Avatar
    Huh... This is a Samsung note 9 forum lol.
    Oh ok. But are you certain you were backing up your homescreen setup? (I don't have a Samsung device, so I'm not familiar with those options.)
    12-11-2020 04:04 PM
  2. B. Diddy's Avatar
    I realize that, which is why I called in @mustang7757 for his familiarity with Samsung. But there are also general concepts that I can try to help with. My question was about actually backing up your homescreen -- if there's an option to turn that on or off, and if yours was off, then you obviously wouldn't be able to restore the homescreen setup.
    12-11-2020 04:19 PM
  3. mustang7757's Avatar
    I agree , your knowledge can help regardless which phone anyone has , Veggie59 also great member here.
    B. Diddy likes this.
    12-11-2020 04:26 PM
  4. Kizzy Catwoman's Avatar
    Yes you can or smart switch
    The Home Up module in Good Lock also gives you the option to back up the home screens. Just FYI.
    mustang7757 likes this.
    12-11-2020 05:01 PM
  5. mustang7757's Avatar
    I believe your right
    12-11-2020 05:08 PM
  6. belodion's Avatar
    If questioners seeking help were to insist on replies only from members with experience of the same device, they might get no replies at all. That’s not what the forums are about, and Volunteers will always offer help if they can.
    12-12-2020 05:06 AM
  7. veggie59's Avatar
    OK... Thanks everyone just thought answers in here were from fellow Note 9 users.
    belodion likes this.
    12-12-2020 08:12 AM
32 12
  1. OneUi beta on VZW?
    By Dagr in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 12-01-2020, 11:28 PM
  2. S10 will not turn on calls with ford sync[Solved]
    By Jonathan Spears in forum Samsung Galaxy S10 & S10+
    Last Post: 11-30-2020, 01:00 PM
  3. Replies: 27
    Last Post: 11-26-2020, 12:37 PM
  4. My Lenovo Tab8 will not connect to my BT Hub
    Last Post: 11-26-2020, 12:26 PM
  5. Why does my phone makes a noise then shutdown?
    Last Post: 11-26-2020, 12:05 PM
