    Hello, I bought 512 gb mmc and tried to use it on my note 9. I used the file default file explorer to move the files, but unfortunately error happens. It says that the videos can't be played, and other error was when I was checking the folder it says empty but the available file size is lessen.
    04-11-2021 12:15 AM
  2. mustang7757's Avatar
    Where did you purchase the sd card ? Lot counterfeit out there , did you use My Files to check your sd card ? Can try total commander in play store.
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    04-11-2021 12:18 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Read this article: How to Spot a Fake MicroSD Card and Avoid Being Scammed
    04-11-2021 12:41 AM
  1. Why can't I directly reply to messages on Instagram?
    By Nagget boi in forum Samsung Galaxy S9 & S9+
    Last Post: 04-11-2021, 05:32 PM
  2. Will there be an update on the S21 Ultra front cam?
    By Android Central Question in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 04-11-2021, 03:08 AM
  3. Will there be an update on the S21 Ultra front cam?
    Last Post: 04-11-2021, 01:46 AM
  4. Google account config issues on android
    Last Post: 04-10-2021, 08:57 PM
  5. Samsung 8. Cant hear the caller unless on speaker or earpiece
    Last Post: 04-10-2021, 07:49 PM
