1. Climb14er's Avatar
    This one I believe will be the last for this phenomenal phone. It should take me till early next year, when the security updates will probably expire. Don't know what phone to transition to... could be another Sammy, Pixel or heaven forbid, iPhone. Definitely want unlocked, dual/esim phone, and will get OS uodates for at least three years... or more. There are choices... ??? The Note 9 continues to serve me well.
    04-14-2021 07:35 PM
  2. mustang7757's Avatar
    Did you do the battery replacement or had a repair center?
    04-14-2021 08:43 PM
  3. Climb14er's Avatar
    Ubreakitifixit. Now owned by Asurion. Verizon picked up the cost under Extended Warranty.
    04-14-2021 08:47 PM
  4. mustang7757's Avatar
    Didn't know they were owned by Asurion now , that's great Verizon covered it .
    04-14-2021 08:53 PM
  5. gray2018's Avatar
    How does it perform with the new battery? I had bought a used Note 9 recently and thought about going this route as well so I could have a brand new battery.
    gendo667 likes this.
    04-15-2021 04:26 AM
  6. Climb14er's Avatar
    Performs fine! Note 9 is a great phone. Just using it a lot, degrades the battery. Back up to speed nicely.
    04-15-2021 08:47 AM
  7. gray2018's Avatar
    Do you notice any difference in battery life?
    04-15-2021 11:39 AM
  8. Climb14er's Avatar
    Yes. Battery lasting longer.
    04-16-2021 09:08 AM
  9. gray2018's Avatar
    How much longer? Like a noticeable difference? I recently purchased a refurbished Note 9 from Samsung and though they say they rebuild devices, the battery life doesn't quite seem as good as it should be.
    04-16-2021 12:21 PM
  10. Climb14er's Avatar
    I just got it the other day. Just go in and get a new Sammy battery.
    04-16-2021 02:34 PM
  1. Need help with new Note 20 Ultra 5g
    By jagrlover in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 04-15-2021, 06:18 AM
  2. note 10 plus flashing error help pleas
    By Android Central Question in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 04-14-2021, 08:58 PM
  3. My tablet charging port is broke
    Last Post: 04-14-2021, 08:46 PM
  4. Why is my phone making a ticking sound
    Last Post: 04-14-2021, 04:36 PM
