09-09-2018 02:01 PM
32 12
tools
  1. anon(10509503)'s Avatar
    What do you bet this adapter they are sending you folks is identical to the one you already have...
    My adapter directly from Samsung was just delivered, once I can get home and get my hands on it I will do a side-by-side comparison with the new adapter and the old Note8 adapter.
    burrzoo likes this.
    09-06-2018 11:02 AM
  2. Gary02468's Avatar
    The Note9 is thicker than the Note8, so the adapter needs a little more space so you don't have to jam the phone in too tightly.
    09-06-2018 02:09 PM
  3. anon(10509503)'s Avatar
    Here's my post about the new Adapter.
    https://forums.androidcentral.com/sa...69-32908a.html
    09-06-2018 02:43 PM
  4. Misterb's Avatar
    That's great! I don't mind being proven wrong in this instance lol
    09-06-2018 03:00 PM
  5. DroidKnight3000's Avatar
    Hi,
    Have you tried this with whitestone dome. Will there be enough clearance to not pop the glass up?
    09-06-2018 03:52 PM
  6. strikeIII's Avatar
    Hi,
    In the Note 8 VR there seems to be enough space for the front of the device that I don't think it would interfere with a screen protector but I don't use a SP to be certain. It's the back of the Note 9 that fits tightly in the USB C connection.
    09-06-2018 04:15 PM
  7. French's Avatar
    Not sure why, but I actually received 2 Note 9 adapters and yes, it is different for sure because I wasn't comfortable trying to jam my Note 9 into the existing adapter. This new one (or two in my case) from Samsung is definitely made to fit.
    09-09-2018 02:01 PM
32 12
  1. Replies: 7
    Last Post: 08-23-2018, 09:25 AM
  2. Note9 is less water-resistant than Note8
    By Gary02468 in forum Samsung Galaxy Note 9
    Last Post: 08-10-2018, 06:30 AM
  3. What's wrong with my phone?
    Last Post: 08-09-2018, 05:36 PM
  4. sim card compatibility?
    Last Post: 08-09-2018, 01:44 PM
  5. S9 car charging very slowly...adaptive fast charger bought with 3.0
    Last Post: 08-09-2018, 01:11 PM
