1. njguy0414's Avatar
    I'm going on about 3 years with my Note 5, and even though I have chargers all over the place, I can't deal with the short battery life anymore. So I've pre purchased an unlocked ocean blue 128GB through B&H photo. They had (for me) the best freebies. You get the Dex pad dock, the wireless charger duo, and also the choice of the headphones or Fornite bucks. I rarely use headphones and don't play Fortnite.
    For the longest time I was a Verizon customer, but got fed up with pricing. I found a deal on T-Mobile for $30 a month, pre-paid. "Unlimited" data (throttled at 5GB), texting, and 100 voice minutes a month. I rarely talk on the phone, and only 2 times in three years have I bumped into the 5GB cap. I went with this plan when I got the Note 5.
    90% of the time, coverage is great. But I do a lot of outdoor photography and there are two things that are very important. Directions, and weather. I usually am out with others, and it bugs me to no end when they have service and I don't when we are in the middle of nowhere. I've downloaded maps ahead of time, but if you go off route, Google maps won't recalculate on the fly. So I've decided to make the switch back to Verizon.
    When I get the Note 9, I'll be mid-billing cycle with T-mobile, so I'll let it run out to get my money's worth. Since I've never switched carriers like this, I just wanted to see if there was any gotchas I needed to be concerned about. Will Verizon charge me for a new SIM card, and then just bring my cell# over? It should be an easy process right?
    I'm hoping I'll see a nice performance jump going from a 5 to the 9 too.
    08-13-2018 09:59 AM
  2. Itsa_Me_Mario's Avatar
    Pretty much, yeah it's a very straightforward process.
    njguy0414 likes this.
    08-13-2018 10:18 AM
  3. Chuckcell's Avatar
    After my Note on AT&T I choose Verizon for my Pixel XL for the same reason you mentioned - coverage in the sticks or remoter. Saitcj over painless and kinda worked out, still some rural-backwaters not covered. Oh well. Also I don't think much of Verizon pricing, $66/month. Not that much of a deal.
    08-13-2018 10:45 AM
  1. Google pixel 2 xl pinkish hue to always on display only when in always on mode.
    Last Post: 08-14-2018, 09:51 AM
  2. Cant open files says dont have app to open
    Last Post: 08-13-2018, 05:31 PM
  3. By mistake i disabled contact list addition how to enable it
    Last Post: 08-13-2018, 04:53 PM
  4. Replies: 1
    Last Post: 08-13-2018, 12:33 PM
  5. how to unlock phone if you did not put in a security pin when you restart
    Last Post: 08-13-2018, 05:42 AM
