1. bpe4's Avatar
    So I ordered the 512 mainly for the 8GB future proofing. The 512 is absolute overkill for my usage so even though I have a 256GB SD in my current phone, I dont plan on moving it over.
    So my question to the peanut gallery is whether or not you think the phone's reading or writing to an SD Card versus internal storage drains the battery faster?
    Personally I would think it does.
    08-18-2018 11:57 AM
  2. evohicks's Avatar
    I don't think it would be noticeble to be honest but the SD card would definately be slower than just the internal storage, again not that noticeble I suppose until it gets pretty full.
    08-18-2018 12:20 PM
  3. methodman89's Avatar
    Yes, it uses power, extra processor and has time delay and compatility issues
    issues with many apps for full functionality.
    If you insist on installing it, only put media.
    KruseLudsMobile likes this.
    08-18-2018 01:06 PM
  4. Misterb's Avatar
    Unless you keep your phones for 2+ years, you aren't really future proofing anything by getting the 512
    08-18-2018 01:22 PM
  5. Golfdriver97's Avatar
    The use of the card would take more energy. I would say it's negligible, though. As for the read/write, it is slower regardless of how full it is.
    Unless you really wanted the 8 GB of RAM, the 512 is most likely overkill. How full is your current phone?
    djrakowski likes this.
    08-18-2018 01:27 PM
  6. joe01880's Avatar
    Get a good card with high read/write speeds, sure it uses meniscal micro voltages. If you have battery issues it's not due to micro SD card drainage. Manage your apps!
    08-18-2018 04:45 PM
  7. bassplayrguy's Avatar
    True but games and apps are getting alot bigger and drain more resources to use, so the 8 Gb will definately help going forward if someone plans on keeping this phone for 2years.
    GS4Bob likes this.
    08-18-2018 06:02 PM
  8. rushmore's Avatar
    Works great for that. Nope for apps. Problematic at best.
    08-18-2018 07:25 PM
  9. methodman89's Avatar
    The 8 gigs of ram is for naught until the app developers get a kit that can access it all.
    08-18-2018 08:23 PM
  1. How do I get rid of an unwanted widget?
    By Gibson1234 in forum Samsung Galaxy S8 & S8+
    Last Post: 11-13-2018, 05:02 PM
  2. How do i change white background on my infinix note 5
    Last Post: 08-18-2018, 01:11 PM
  3. How do I customise ringtones in Samsung Galaxy S9
    Last Post: 08-18-2018, 01:02 PM
  4. Sd card not showing in file explorer
    By Knight Phantom in forum General Help and How To
    Last Post: 08-18-2018, 12:08 PM
