1. ncridgerunner's Avatar
    I have searched extensively to determine if the T-Mobile Note 9 is 600MHZ capable and get conflicting info.
    Living in a rural area makes this a desirable feature.
    08-19-2018 07:51 PM
  2. madviking74's Avatar
    yes the note 9 has 600 band radio..so does s8
    08-19-2018 08:15 PM
  3. ncridgerunner's Avatar
    Much appreciated madviking. Can I ask where you found this info? The T-Mobile site does not list the Note 9 and the websites I viewed are inconclusive.
    08-19-2018 08:20 PM
  4. iosroid's Avatar
    Yes Samsung Galaxy Note9 does support Supports 600 MHz (Band 71) & 700 MHz (Band 12). I have confirmed it with Tmobil support.
    08-19-2018 08:20 PM
  5. ncridgerunner's Avatar
    Great! Thanks iosroid!
    08-19-2018 08:22 PM
  6. TechBob's Avatar
    The T-Mobile branded Note 9 will, as does the S9/S9 Plus that the hardware is based on. The jury is out on the unlocked model. It would be a step back for them not to have support for it. The Note 8 Snapdragon 835 added support for it, but just a little too late for the Note 8. It should be on all T-Mobile Samsung phones from this point forward.
    08-19-2018 08:24 PM
  7. madviking74's Avatar
    i can't find where i saw the info on 600 and 700 band but it looks like others here have seen the same info....!!
    08-19-2018 08:30 PM
  8. ncridgerunner's Avatar
    Sounds good.
    08-19-2018 08:32 PM
  9. gendo667's Avatar
    I think it's table steaks for a flagship device at this point.
    08-19-2018 08:36 PM
  10. jlangner's Avatar
    https://www.t-mobile.com/cell-phone/...DZ54VO61C14166
    Here is info:
    Quad Band GSM
    LTE: 2, 4, 5, 12, 46, 66, 71
    UMTS: Band I (2100), Band II (1900), Band IV (1700/2100), Band V (850)
    Itsa_Me_Mario and Cary Quinn like this.
    08-19-2018 08:37 PM
  11. ncridgerunner's Avatar
    Thanks. I spent more than a couple of hours trying to get this info. Guess I was going to the wrong T-Mobile page.
    08-19-2018 08:41 PM
  12. durandetto's Avatar
    Now if tmobile would just roll it out in more areas.
    08-19-2018 08:42 PM
  13. Carrie Greicar's Avatar
    I have also confirmed with T-Mobile.
    08-20-2018 06:49 AM
  14. Ryano89's Avatar
    The S8 does not. The V30 was the first TMobile phone with 600mhz capabilities. That's ethe only reason I'm looking to upgrade a perfectly good Note8.
    08-20-2018 06:59 AM
  15. madviking74's Avatar
    i know that note 8 doesn't support it ...but s8 and s8+ does
    Samsung announced the Galaxy S9 and S9+ yesterday, but the news for T-Mobile subscribers doesn't stop there. Turns out the new Galaxy phones support team magenta's new 600MHz band 71 LTE. So if you've got your heart set on taking advantage of the frequency's extra coverage and penetration in the coming years, then the S9 and S9+ are your best bet right now. this was from press release when s8 s8+ was released earlier this year.....
    08-20-2018 12:04 PM
  16. jlangner's Avatar
    That is S9 that was released this year not S8
    Cary Quinn likes this.
    08-20-2018 12:26 PM
  17. madviking74's Avatar
    i mean s9 and s9+ instead of s8 and s8+
    08-20-2018 02:07 PM
  1. Android system icon not appearing when I drag down the status bar
    Last Post: 08-21-2018, 02:56 PM
  2. Pre order note 9
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 08-19-2018, 09:47 PM
  3. What is this icon in my notification bar?
    By No Worries in forum Ask a Question
    Last Post: 08-19-2018, 08:23 PM
  4. Is there a way to have different equalizer settings for different apps?
    Last Post: 08-19-2018, 08:21 PM
  5. Pre order note 9
    Last Post: 08-19-2018, 06:17 PM
