1. petereffendy's Avatar
    Base on first charge, it stated only 3824 mah
    08-23-2018 05:06 AM
  2. methodman89's Avatar
    Read the whole thing. It's an estimate, based on 1 charge cycle. Let it gather more data over time to get more accuracy.
    08-23-2018 05:17 AM
  3. TriBeard92's Avatar
    https://i.imgur.com/6bopySe.jpg
    Most batteries also don't charge to 100% of actual capacity, despite what the status bar tells you to protect themselves/decrease wear long term.
    08-23-2018 08:09 AM
  4. anon(20964)'s Avatar
    It may be defective. IDK.
    08-23-2018 08:21 AM
  5. petereffendy's Avatar
    When the first time I charged note 8 with accubattery, the result is 102%, 2% bigger than factory claimed.
    My phone also feels hot, hotter than Note 8. Mine the exynos version.
    recDNA likes this.
    08-23-2018 10:02 PM
  6. petereffendy's Avatar
    Anybody who use Note 9 please install accubattery and screen shot the actual battery capacity after charging it to full 100%, thanks.
    08-23-2018 10:03 PM
  7. strikeIII's Avatar
    Mine showed as slightly above capacity but not all batteries are created equal. There will be slight differences between all.
    08-24-2018 08:13 AM
  8. anon(20964)'s Avatar
    Mine showed as slightly above capacity but not all batteries are created equal. There will be slight differences between all. https://uploads.tapatalk-cdn.com/201...ef3d950331.jpg
    Always good to be on the larger side though. My Note 8 battery was like that too (reported on the high side) and it is still going strong 10 months later.
    Personally, I'd be leery if it reported on the low side out the gate. But it's probably ok. IDK.
    08-24-2018 08:34 AM
  9. art_d's Avatar
    Mine is reported 97% with 3861 mAh capacity after first charge
    Nostromo79 likes this.
    08-25-2018 10:58 AM
  10. recDNA's Avatar
    I doubt Samsung nor Carriers would accept app battery calculations as a cause for exchange.
    08-25-2018 01:44 PM
  11. Ry's Avatar
    It's an estimate.
    08-25-2018 01:56 PM
  12. bassplayrguy's Avatar
    Those apps are garbage.
    08-25-2018 04:11 PM
  13. petereffendy's Avatar
    I think the battery need time to break in, I turned off my phone and charge it to 100% and wait it for 4 hours remaining full. Then I uninstall the apps and reinstall it again, the result is higher this time but still less than 4000 mah.
    Ry likes this.
    08-27-2018 02:35 AM
  1. Sprint Note 9 does NOT have Calling Plus
    By Starfleet Captain in forum Samsung Galaxy Note 9
    Last Post: 02-24-2019, 12:45 PM
  2. Unlocked Note 9 At&t Wi-Fi Calling?
    By xchris5442x in forum Samsung Galaxy Note 9
    Last Post: 01-06-2019, 01:38 PM
  3. Replies: 1
    Last Post: 08-23-2018, 12:11 PM
  4. MKHD review of the note 9
    By NIZMOZ44 in forum Samsung Galaxy Note 9
    Last Post: 08-23-2018, 10:56 AM
  5. Replies: 1
    Last Post: 08-23-2018, 02:16 AM
