1. corvette72778's Avatar
    Just got my T-mobile Note 9 yesterday and opened it last night so I've haven't had it even a day. But my first impression is that the battery is draining quicker than I expected. Left My Note 9 and 8 by each other before going to sleep in airplane mode with Wifi on and they both lost about 10%.
    I also noticed the Note 9 running hotter than my 8. I have the US SD845 version.
    How is your battery life for your note 9 vs note 8?
    08-23-2018 09:21 AM
  2. brau0303's Avatar
    My Advice, give it a week and make sure all of your sync settings are tuned and then see what the battery performance is then. Also, if you did a data xfer from device to device (even if it was a Note 8, there could be differences or something that can cause battery performance issues)
    Cheers,
    BR
    08-23-2018 10:00 AM
  3. rushmore's Avatar
    Respectfully can't see how battery life can be judged with a new phone just out of box. Android for better or worse is still reviewing the installed apps to determine queuing and application residence in ram. I have always noticed higher battery use and warmer device for first few days.
    This does not even count the additional use the device is likely getting, since a new device.
    08-23-2018 10:05 AM
  1. Sprint Note 9 does NOT have Calling Plus
    By Starfleet Captain in forum Samsung Galaxy Note 9
    Last Post: 02-24-2019, 12:45 PM
  2. Samsung Note 9 Pre Order from B&H
    By jjjjcccc in forum Samsung Galaxy Note 9
    Last Post: 08-29-2018, 01:05 PM
  3. Note 9 actual battery is lower than 4000 mah?
    By petereffendy in forum Samsung Galaxy Note 9
    Last Post: 08-27-2018, 02:35 AM
  4. Note 9 display warmer color temp
    By willpooted in forum Samsung Galaxy Note 9
    Last Post: 08-23-2018, 11:12 AM
  5. Note 9 Buyers in India
    By jeetu4444 in forum Samsung Galaxy Note 9
    Last Post: 08-23-2018, 09:19 AM
