1. donb2010's Avatar
    Can anyone recommend a slim case with cutouts for the buttons? I'm not a fan of the "fake buttons" that cover the actual buttons.
    08-29-2018 06:19 PM
  2. Itsa_Me_Mario's Avatar
    Peel should have a Note 9 case soon.
    08-29-2018 07:48 PM
  3. sux2bu's Avatar
    I was hoping Samsung would have one. They did for my Note 8 and it was crazy slim and had the buttons open. I really liked it.
    https://forums.androidcentral.com/e?...token=830cgRKe
    08-29-2018 09:16 PM
  4. bunsen's Avatar
    MNML is on Amazon. It wasn't available when I made my purchase, but this one is similar too... I'm having issues pasting links, so search for memumi note 9 on Amazon. It's a nice matte .3mm case for about $11.
    09-02-2018 10:26 PM
  5. bunsen's Avatar
    Got the link to paste... Galaxy Note 9 Case, memumi 0.3 mm Ultra Thin Compatible with Samsung Galaxy Note 9 Matte Finish [Fingerprint Resistant] Cover Note 9 Slim Phone Case (Transparent Blue) https://www.amazon.com/dp/B07G36Q2G4...cUvbUpU6329908
    09-02-2018 10:27 PM
  6. awtryau89's Avatar
    Got the link to paste... Galaxy Note 9 Case, memumi 0.3 mm Ultra Thin Compatible with Samsung Galaxy Note 9 Matte Finish [Fingerprint Resistant] Cover Note 9 Slim Phone Case (Transparent Blue) https://www.amazon.com/dp/B07G36Q2G4...cUvbUpU6331322
    Got this one and its perfect. I had the Spigen Airskin for my Note 8 and this case is exactly the same but different brand. Love the way the fingerprint sensor cut out is not raised but camera is. Helps with false touches. Blue matches my blue perfectly. I have always used these type cases over skins. Basically the same as a skin with a bit more drop protection for scratches only.
    09-04-2018 09:48 AM
  1. Don't buy this case or screen protector.
    By sux2bu in forum Samsung Galaxy Note 9
    Last Post: 08-30-2018, 08:31 AM
  2. I want to open Shazam from my lock screen without PIN
    Last Post: 08-29-2018, 10:24 AM
  3. Android should use security password/fingerprint in case to turn-off the phone?
    Last Post: 08-29-2018, 05:45 AM
  4. Replies: 4
    Last Post: 08-29-2018, 04:42 AM
  5. Replies: 0
    Last Post: 08-28-2018, 05:31 PM
