Battery Drain on Note 9 suddenly
NIZMOZ44
1,137
I am hoping someone can help me figure out what is going on. I was getting 6 hours or more usage for screen on time, and now my battery is draining pretty fast on it's own. Here is my battery usage from today with very little use. Just 1 hour of screen usage. Android System seems to be the biggest issue. Any ideas what I can do with that?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
When you got 6 hours of screen on time, was that with pretty much continuous use, or was that also with plenty of idle time mixed in?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
Try look into bluetooth/NFC
I see that you use it, maybe the battery issues are there..
bandofbrothers2112
Trusted Member
May 30, 2016
2,127
38
It could be a rogue app.
Perhaps put the phone in safe mode which turns off all your downloaded apps and leaves the stock ones alone which can help to determine if an app is causing this situation.
bandofbrothers2112
Trusted Member
May 30, 2016
2,127
38
If it was a rogue app it would be showing up under the usage pic I posted.
That's if it's being reported correctly by the phone.
I mentioned Safe Mode as this is part of the Process of Elimination processes people use to self help diagnose.
Maybe a Samsung Experience Store or Service Centre will be able to help you further via a diagnostic on the phone.
NIZMOZ44
1,137
Sadly we don't have one in 200 miles.
RemusGhostofRome
