1. cbaird254's Avatar
    Hey all. Just wanted to check in. Got my Note 9 on launch (128gb blue) and so far the phone is incredible. I switched from iOS to Android last year and cannot see myself switching back. I am coming from a note 8.
    So far I feel that my battery life is extremely poor. I barely use my phone during the day (I work for a moving company). I'm constantly on the go. I don't stream music or watch YouTube, I always have good service. Never use the GPS navigation. Always on display is off. I feel like my Note 8 had a better battery life. I posted a screenshot of the battery life under phone maintenance. This is from 745am today until just now around 945.
    Does everything seem normal here or does something seem wack? I'm not getting "all day" imo. Not sure what to do! Any advice is appreciated!!
    Chris
    09-06-2018 09:09 PM
  2. catspyjamas's Avatar
    Something definitely seems off about that to me. It is 2.20pm in NZ - my phone was taken off the charger at 8pm last night. I am on 91% currently, with an estimated remaining time of 1 day + 21hrs. I am not using power saving mode, wifi, & location is switched on, as are most notifications. Admittedly I had it switched to "Do not Disturb mode" for 9hrs overnight, also I have disabled "always on display". I have made one call, sent some texts and done a little browsing today but not much else.
    EDIT will try and attach screenshot. Apologies in advance if it doesn't work.
    09-06-2018 09:23 PM
  3. anon(20964)'s Avatar
    I haven't exactly been keeping detailed notes and data on battery life with Note 9, but I can say it is much better than the Note 8 I had previously.
    I'm just enjoying this awesome phone / life assistant right now.
    09-06-2018 09:35 PM
  4. jayk82's Avatar
    Having similar issues as OP. Android System is killing my battery as well.
    09-06-2018 09:47 PM
  5. Victor Hernandez Jr's Avatar
    battery life alone I suggest this phone, been off the charger for almost 10 hours pretty heavy usage and I still have 60%
    09-06-2018 10:25 PM
  6. evohicks's Avatar
    Exynos or Snapdragon, you know the drill
    09-07-2018 12:34 AM
  7. Gary02468's Avatar
    This is the fourth thread about battery life in this forum. The more threads there are for a given topic, the more spread-out the information is, making it harder to find.
    09-07-2018 07:13 AM
  8. smooth4lyfe's Avatar
    Mine currently with pretty heavy usage today...this is what I did
    - Get a darker theme
    - Auto brightness off
    - Google location services off
    - Wifi scanning off
    - Don't download too many apps that run in the background or turn off notifications for the apps u don't use
    09-07-2018 06:40 PM
  9. jeetu4444's Avatar
    guys make sure u disable android system to run in the background ..saves lot of battery...I am getting great battery life....Indian version dual sim exynos version
    And make sure to disable background wifi and bluetooth scanning ...which is on by default
    09-07-2018 07:45 PM
  10. smooth4lyfe's Avatar
    How do u do that?
    09-07-2018 08:00 PM
  11. jeetu4444's Avatar
    How do u do that?
    Here is the screen shot
    09-07-2018 08:21 PM
  12. jayk82's Avatar
    I do that, and it continuously turns itself back on!
    09-07-2018 08:26 PM
  13. beavo451's Avatar
    I had that same problem. The phone would get hot whenever the screen was on. A factory reset fixed it and now I'm getting 5.5 hrs screen time with 20-30% battery left.Battery Life-screenshot_20180907-200245_settings.jpg
    09-07-2018 08:26 PM
  14. jayk82's Avatar
    I had that same problem. The phone would get hot whenever the screen was on. A factory reset fixed it and now I'm getting 5.5 hrs screen time with 20-30% battery left.Click image for larger version.
    Oh man, I was hoping to avoid doing a fa story reset, but if it fixes it...
    Guess I know how I'm spending my Friday noght!
    09-07-2018 08:32 PM
  15. smooth4lyfe's Avatar
    Hmmm maybe it has to be running
    09-07-2018 08:43 PM
  16. Kilroy672's Avatar
    What do you lose when doing a factory reset? Since I can't do a smart switch without another phone. I know that I keep up with my Samsung and Google backups. What about all my text and phone logs and pics?
    09-07-2018 11:10 PM
  17. sweetypie31's Avatar
    You lose everything on the phone when you do a factory reset. It takes the phone back to it's original state as if you just got it.
    09-07-2018 11:55 PM
  18. linkiik121's Avatar
    My battery is always able to do 7+sot. Love it!
    09-08-2018 12:03 AM
  19. linkiik121's Avatar
    Full screen shot
    09-08-2018 12:05 AM
  20. evohicks's Avatar
    You could use a PC to do smart switch also.
    09-08-2018 01:46 AM
  21. cbaird254's Avatar
    Snapdragon -_-
    09-08-2018 07:57 AM
  22. Kilroy672's Avatar
    How do I do that with a PC?
    09-08-2018 08:04 AM
  23. jgraves1107's Avatar
    Honestly when you have issues with a new device look at your backups to be the cause. Corruption in the file structure. Save all pertinent data and reset to factory. Then set it up as new. Fixes a lot of issues.
    09-08-2018 08:32 AM
  1. Battery Life Post September 2018 Update
    By The Lip in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-11-2018, 06:48 PM
  2. Is it my battery or my phone?
    Last Post: 09-06-2018, 02:19 PM
  3. Samsung Galaxy J3 (2016) battery draining fast.
    By Shutterbug99 in forum Samsung Galaxy J Series
    Last Post: 09-06-2018, 01:57 PM
  4. Why does my htc u11 life screen glitch
    Last Post: 09-05-2018, 05:33 PM
  5. Rapid battery drain from 100% to 0% while off
    Last Post: 09-05-2018, 03:50 PM
