wow,finally someone like me.i used to use Softlock but since it cant override the safety bla bla bla i use assistive touch(in settings) to lock my screen...
btw do you happen to be OCD about buttons? xD
Printable View
No OCD, just like to prolong the buttons. I know these buttons are designed to last an unknown number of times, but I just don't like to press it 100x a day.
BTW, I've finally found an app called "turn off screen (lock screen)" by redmanit to be working with the note 9, it even has the option to lock the screen from the notification bar.
wow.is the app safe?and safe to unlock with iris?
Go check it out on the play store. It has screenshots of what permission is required; device admin and 2 others. It works with fps and intelligent scan, which I'm using. One thing to note though, once you press their icon to lock the phone, it actually blacks out the screen for 5 seconds, and then it truly locks.
owh so theres a 5 second delay...Nova Launcher does that too...i thought i could use it like softlock...but thanks for the tips.
Most likely it's the app, though... try it without it (locking the screen with the power button or letting it lock itself after standby) and you'll see. That random prompt shouldn't be more than a couple times a week on normal conditions.
Damn it works to my s9plus pie. I'm also using nova launcher double tap to lock screen with activate device admin. Sadly now it always requires a pattern to unlock my s9 rather than using registered intelegent scan or finger. Now i have to not use my purchase nova launcher
