Just a little bit ago as always sending text messages back and forth with my husband the phone decided it's going to just start typing a whole bunch of number 8 and it kept typing them like I was continually pressing that key
I'd say do a wipe cash partition first before taking the reset plunge and see if that help alliviate the behavior.I think I'm going to factory reset it because not only was it doing that when I would go to tap on a folder on my homepage to pick an app with in that folder it would open it and then close it I would get into the app after a second try it would open it all the way and then close it
I did wipe the cache partition but it started typing the number 8s again. I was on the phone with Samsung tech help and as I was dialing and going through their menu prompts my phone made a long beep noise like I was holding down the number 8I'd say do a wipe cash partition first before taking the reset plunge and see if that help alliviate the behavior.
Nova. Had it since Aug 22. This weird issue started 10 min ago. Stock keyboard. Samsung themesTake it gradual as you install apps, too.
A case might trigger erratic touch.
Try just wiping cache partition..
Boot into Safe mode once or twice.
What launcher? Keyboard? are you using? Stock or 3rd party?
Just a little bit ago as always sending text messages back and forth with my husband the phone decided it's going to just start typing a whole bunch of number 8 and it kept typing them like I was continually pressing that key//uploads.tapatalk-cdn.com/20180912/a0799833479b3000fd3e1af2a2f1d829.jpg
Lol my autistic son probably went with his aide. We went to Quaker lubeMore importantly, is that now an open invitation to Applebee’s? Thank you please, I’m starving!
How do you like the tab s4. Nice looking techHopefully it stays that way. I had to resent my tab s4 last night after two weeks of usage now the iris scanner is working as it should beforehand it was working but not how it was supposed to. And it all started from the notification shade went invisible.
Ill strongly agree thereIts a beautiful slab. It's light S pen display is gorgeous its snappy speakers are top notch dex built in its pricey yes but nothing in the cheaper class android wise can touch it
