09-14-2018 04:58 PM
32 12
tools
  1. amyf27's Avatar
    Just a little bit ago as always sending text messages back and forth with my husband the phone decided it's going to just start typing a whole bunch of number 8 and it kept typing them like I was continually pressing that key
    Jewels81 likes this.
    09-12-2018 04:40 PM
  2. amyf27's Avatar
    I think I'm going to factory reset it because not only was it doing that when I would go to tap on a folder on my homepage to pick an app with in that folder it would open it and then close it I would get into the app after a second try it would open it all the way and then close it
    09-12-2018 05:06 PM
  3. LordAndroid's Avatar
    I'd say do a wipe cash partition first before taking the reset plunge and see if that help alliviate the behavior.
    09-12-2018 05:28 PM
  4. amyf27's Avatar
    I did wipe the cache partition but it started typing the number 8s again. I was on the phone with Samsung tech help and as I was dialing and going through their menu prompts my phone made a long beep noise like I was holding down the number 8
    09-12-2018 05:30 PM
  5. Gayle Lynn's Avatar
    Take it gradual as you install apps, too.
    A case might trigger erratic touch.
    Try just wiping cache partition..
    Boot into Safe mode once or twice.
    What launcher? Keyboard? are you using? Stock or 3rd party?
    09-12-2018 05:30 PM
  6. amyf27's Avatar
    Nova. Had it since Aug 22. This weird issue started 10 min ago. Stock keyboard. Samsung themes
    09-12-2018 05:40 PM
  7. Jewels81's Avatar
    Just a little bit ago as always sending text messages back and forth with my husband the phone decided it's going to just start typing a whole bunch of number 8 and it kept typing them like I was continually pressing that keyhttps://uploads.tapatalk-cdn.com/201...f2a2f1d829.jpg
    Shoot I would do an exorcism. That thing is possessed. Or Apple put a spell on your note9 since the next iPhone coming lol🤪
    09-12-2018 05:43 PM
  8. LordAndroid's Avatar
    Try using a different keyboard see what happens
    anon(3641385) and EgretOwl2 like this.
    09-12-2018 05:43 PM
  9. anon(3641385)'s Avatar
    Just a thought, try typing an email, or a word document, or whatever. See if the same thing happens.
    It'd be funny if it wasn't serious, lol. (bet on something that has a number 8 😁)
    EgretOwl2 likes this.
    09-12-2018 05:47 PM
  10. rsmin's Avatar
    Sounds like you have some good advice from different ones for thinks to try before the reset.
    09-12-2018 05:51 PM
  11. amyf27's Avatar
    Its been factory reset very recently. So far so good
    pkcable likes this.
    09-12-2018 06:53 PM
  12. Paul Ellis1's Avatar
    More importantly, is that now an open invitation to Applebee’s? Thank you please, I’m starving!
    djrakowski and amyf27 like this.
    09-12-2018 06:58 PM
  13. amyf27's Avatar
    Lol my autistic son probably went with his aide. We went to Quaker lube
    09-12-2018 07:03 PM
  14. amyf27's Avatar
    So far so good now about 2 hrs later
    09-12-2018 08:05 PM
  15. LordAndroid's Avatar
    Hopefully it stays that way. I had to resent my tab s4 last night after two weeks of usage now the iris scanner is working as it should beforehand it was working but not how it was supposed to. And it all started from the notification shade went invisible.
    amyf27 likes this.
    09-12-2018 08:13 PM
  16. amyf27's Avatar
    How do you like the tab s4. Nice looking tech
    09-12-2018 08:16 PM
  17. LordAndroid's Avatar
    Its a beautiful slab. It's light S pen display is gorgeous its snappy speakers are top notch dex built in its pricey yes but nothing in the cheaper class android wise can touch it
    anon(3641385) likes this.
    09-12-2018 08:20 PM
  18. amyf27's Avatar
    Ill strongly agree there
    09-12-2018 08:23 PM
  19. amyf27's Avatar
    Update: since the reset yesterday around 6:40pm eastern time, no issues. Current on stock launcher, only picked a handful of apps to download and a few to restore.
    Likely will go back to Nova Launcher though soon.
    pkcable likes this.
    09-13-2018 05:06 AM
  20. Paul Ellis1's Avatar
    Restaurants sound so much better wherever you are! If a Quaker Lube ever opens in the uk, I’m eating there, don’t even care what they serve
    amyf27 likes this.
    09-13-2018 03:52 PM
  21. Rukbat's Avatar
    I've never had anything but Nova on any phone for more than the first few minutes - bypass setup, install Nova, then set it up. Years of Nova - paid - with Tesla Unread. Never once had that problem. So you can probably put Nova back. (I hope you backed up the Nova setup.)
    09-13-2018 04:03 PM
  22. amyf27's Avatar
    Here are a few of the restaurants in Northeast Ohio. Firebirds, Stone Bridge, O'Charley's, Texas Roadhouse, Outback, Red Lobster, BJ's Brewhouse, Buffalo Wild Wings.
    Paul Ellis1 likes this.
    09-13-2018 05:01 PM
  23. EMGSM's Avatar
    This is good to hear. That's pretty crazy stuff.
    09-13-2018 08:04 PM
  24. amyf27's Avatar
    Over 24 hrs later and it's doing great
    EMGSM likes this.
    09-13-2018 08:43 PM
  25. Dooki's Avatar
    They do oil changes, they have vending machines though.
    09-14-2018 11:59 AM
32 12
  1. DEX problem
    By scarmel91 in forum Samsung DeX
    Last Post: 09-13-2018, 08:35 AM
  2. Why my moto z play screen is getting really hot?
    Last Post: 09-12-2018, 10:05 PM
  3. My galaxy s8 back camera light problem in low light
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 09-12-2018, 02:18 PM
  4. My galaxy s8 back camera light problem in low light
    Last Post: 09-12-2018, 12:31 PM
  5. Fingerprint problems with Oreo
    By src1425 in forum Samsung Galaxy S7 edge
    Last Post: 09-11-2018, 04:04 PM
