Did you scroll down to the rest of the list?my battery usage is 85%, but the apps using the battery only show as having used 6%, so what else is using the battery that isn't being shown
What's using the extra 9%?
I may be wrong, but I believe those numbers are how much of the battery that was used, was used by that app. In other words, you've used 15% of your battery. Within that 15%, the screen was responsible for 3%. Android system used 1% of that 15%, and so on. Many apps may not be shown due to lower percentages. Several apps are probably using less than 1%. But added together, they account for more
Wipe cache partition? Essential, helped me.I'm one of those people whose battery has started to go berserk. So far I've uninstalled email, always on display, edge lighting, smart view, s pen remote; and whilst the battery drain has slowed down, I now get inconsistent battery usage results
(I ordinarily don't have on: location, Bluetooth, wifi, NFC etc so they're not implicated in this issue)
But if the numbers are the percentage of battery-drain, rather than the percentage of total battery capacity, that makes it even more mysterious, because then 94% of the battery drain is unaccounted for in the OP.I'm with music_man185 with this one, I think he's right. It just takes a bit getting your head around it.
I've got everything on except NFC
AOD and Edge are off.
Dark wallpaper
Poor cell signal at home, using Wi-Fi Calling
Facebook and services - disabled
100 variables and apps
