1. DanielLoreti's Avatar
    How often should I optimize when I'm in device maintenance?
    09-23-2018 10:16 AM
  2. B. Diddy's Avatar
    I'd say never. "Optimizing" typically means killing apps in the background, which really does nothing overall, since the system will restart apps automatically to fill RAM. It will also probably clear all app caches, which is fine if you're running low on internal storage (which is unlikely on a Note9), but this will slightly impact the performance of your apps, since they rely on cached data to start up and function more smoothly.
    kptsalami likes this.
    09-23-2018 11:26 AM
  1. Adaptive Battery - battery drain
    By Dan L2 in forum Google Pixel & Pixel XL
    Last Post: 10-14-2018, 09:40 AM
  2. How is the battery life on galaxy s8 with oreo?
    By Stan_oela in forum Android 8.0 Oreo
    Last Post: 09-26-2018, 11:06 AM
  3. Gear S3 battery life with AOD.
    By Android Central Question in forum Samsung Gear S3
    Last Post: 09-24-2018, 08:50 AM
  4. note 9 max battery life
    Last Post: 09-23-2018, 12:38 PM
  5. Battery life
    By Ziad17 in forum Samsung Galaxy Note 9
    Last Post: 09-22-2018, 08:05 AM
